Another Oil leak
Hud
I've got a oil leak which I thought was the oil pressure sensor but turns out its not...
Could it be the rear main or does it have something to do with my oil pan...
This is where it looks like its coming from...Sorry for the blur... its the backside of the oil pan where it meets the tranny...
And this is under neath that
And this is of the other side of the pan... bone dry
I had a leak that looked the same way. Turns out it was due to the oil filter when removing and changing the filter. all that oil drips out and just sits on that little shelf above the oil pan and it slowly starts spraying out all over the place when you drive. I would put an oil filter relocation kit on and see if it stops. Mine stopped right after I relocated it and gave it a good pressure washing. Or just give it a good wash and see if it stops then install the kit if it does.
Mark
