removing and cleaning idle control valve
zor
I have an idle control system alarm on my 98 pathy. I suspect the valve is just in need of cleaning because of built up carbon residue. I cannott seem to find the location of the valve any help would be appreciated and also what would be the best thing to clean it with?
not sure about the 98 year models, but on mine (1990) the Idle Air Control Valve is located on the underside of the Plenum....towards the back.
And I have mentioned in another post about it being one boneheaded place for Nissan to put it since you cannot access it unless you remove the plenum.
All other vehicles I have ever seen or worked on, its located up beside the throttle body or thereabouts, where you can access it!
