Inside dissasembly
AlMac
Hey guys,
Finally getting around to mounting my ham radio and am routing wires underneath panels for the ham's 'head' unit.
Is there a trick/special procedure for removing the left side 'A' Pillar, and the cap that covers the rear view mirror mounting?
I tried to remove the mirror mounting cap today, but the bugger was pretty stubborn! :unsure:
I'm afraid to force it cause i dont want to break anything.
thanks for your input guys.
coolio.. thanks Terrano..
what kinda tool do u use to take panels off, just a flat screwdriver or something special?
I think im going to mount my main unit under my drivers' seat cause there isnt really a lot of room under the dash for it.
I think removing the seat will prolly be the easy part. Everything else, like the A Pillar looks like its gonna be a pain in the arse to remove...
When i finally get things going, i think i'll make a 'work log' with pics in the garage section for this project.
Here's the rear view cover off. See the 2 tabs (and the munched up side :D ) Does require a lot of force to remove it.
This has 3 clips, I think I fed a screwdriver down the guts to pop them. Inside the red circle is a hook that needs to be pulled up.
Good luck :beer:
thanks for the quick reply.
looks like a screwdriver will handle it all, although im concerned a bit on how the a pillar fits between the dash and the body.
guess ill just take it slow and see what happens!
thanks again! :beer:
