Side Marker Light Assembly
zonianbrat
Just wondering if anybody has any literature or a blown-up view of what the side marker assembly is where and how it connects to the truck. Reason I ask is like 3 years ago I rolled my truck on it's side so the doors and front fender had to be replaced. Well the work was done quite well I am satisfied but I recently took a road trip and noticed that my side marker was hanging on by the bulb and wires. I had to totally remove it and I got to looking at it and tried to see if it just popped out, but it turns out that when you go to put it into the fender (for lack of better term) the bottom stub thingy is supposed to go into some kind of gromet or something I presume but when I went to install it I looked and there is a big hole instead of the gromet thingy. I just assume it is a gromet but am not sure since it is not there. So my light will not stay in I have to get a new side marker lens anyway since I had to rip it off and when I did I broke the molding that attaches it at the top. Before I get flamed and told to just take out the passenger side to look I litteraly do not have the time. I am working on location and it would not be a good thing if I was out working on my truck when I should be creating logs etc. It is just not a good idea.The search function did not help much So I am asking for help here. That way when I finally do go home I will know what I need exactly. So does anybody know what this gromet type thing is I need to hold on the bottom stub portion of the side marker light? Thanks
