XPLORx4 Posted September 6, 2007 Share Posted September 6, 2007 I am thinking about having swapping my camshafts with regrinds from Schneider Cams. I understand the new grind will require new lifters. Is that correct, or can the old lifters be used with the new cams? If I need new ones, where is the best place to order them from? Anyone have a part number? Thanks. Link to comment Share on other sites More sharing options...
jj big shoe Posted September 7, 2007 Share Posted September 7, 2007 Schneider highly recommends replacing the lifters with the cams, but you could resurface your old lifters with 1000 grit sandpaper using a flat, level surface to work on. Once you've got them to a mirror-like finish, stand them up in a bowl of oil and heat the oil to 100*-150*F to thin it and shake the bowl for 5-10 minutes. This is supposed to re-oil the lifters and get any air pockets out. I haven't tried it, but I heared it works ok. I was thinking of reusing mine, but I figured why risk a dollar to save a dime, you know? So I'm going to take the hit and buy all new ones once they send my cams back. I'd like to know where to get them at a good price, too. I've seen OE ones ranging from $13 to $18 each but I'd really like to get them for ~$10 if I could. The part # for the VG30 ones is 13231-v5005, don't know if that will help but there it is. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 15, 2007 Share Posted September 15, 2007 They use to be ~$10 when I looked at them a couple of years back but now the cheapest I've found them were ~13 dollars for one. The ones I bought are at AZ made by Melling. Link to comment Share on other sites More sharing options...
