Guest Kopec Posted May 30, 2004 Share Posted May 30, 2004 I have recently isolated my "Nissan Shimmy" problem to the Rear Lower control arm bushings. After much difficultiy in breaking the bolts, I have found that all 4 bushings are either cracked, torn and otherwise demolished. I have recieved bushings from Automotive Customizers (AC) and am in the process of trying to install them into the control arms. I received the bushings that were pictured for 1996 - 2000 model year Pathfinder - rear lower control arm bushings. A number of prevous threads have indicated the use of a vise instead of a press due to control issues ( i.e. the bushing popping out and hitting you in the face). But I just cannot believe that these bushing are the correct ones - we are talking about pressing a 2.5" diameter (shoulder of bushing) through a 2" hole. Am I missing something. Any ideas would be greatly appreciated. Link to comment Share on other sites More sharing options...
sw Posted May 30, 2004 Share Posted May 30, 2004 umm i probably woundnt try it myself (thats big for me to say that...) you should obviosly have the arms out of the vehicle, so take them to a 'fitter & turner' and get them to press the bushes in. they will have the right press and will do it easy if you do it with a vice you run the chance of damaging the bushes what ever you do DONT take it to a stealer unless you wanna get ripped Link to comment Share on other sites More sharing options...
Guest Kopec Posted May 31, 2004 Share Posted May 31, 2004 Thanks for the feedback. I am sure now that the bushings I ordered from AC were not correct. They offer two types of lower control arm bushings, but the ones I need - they call the "trailing arm" bushings - this terminology is quite confusing - as the Chilton and Nissan shop manuals call them the lower control arm - rear suspension bushings. Perhaps, I recieved the rear bushings for the front lower control arms. In any case, with any luck, I will have the correct bushings soon and can proceed with the job. Link to comment Share on other sites More sharing options...
Trvlace Posted June 1, 2004 Share Posted June 1, 2004 You will not beleive the difference it will make. Be sure to get some nice gas shocks for the rear and some gas struts up front. It will drive like a new one, well better really. The rear end on mine is so stiff I can just whip it in a turn nail the gas the the rear end slides right around. Nice. No where near the body roll in on ramp and that type driving too. Link to comment Share on other sites More sharing options...
Guest Kopec Posted June 3, 2004 Share Posted June 3, 2004 Well, I got the right part. Unfortunately, Automotive Customizers was unwilling to recognize the confusion that I had with the terminology of their part. So all I can do is post here and hope no-one else reading this has the same dificulty. Parts diagrams on auto part web sites is a good thing. In any case, I would recommend this modification to any Pathfinder operator. It not only fixes the problem, but possibly provides a better / tighter feel than when new. Pressing in the bushings is no big deal - having this professionally done is not necessary. A Bench vise and some grease is all you need to perform the task. Just make sure that you place a block of wood or similar under the bushing and sleeve of the control arm - so that the bushing does not pop out from the bottom end of the "sandwich". If you take on this job, just make sure that you treat the bolts/ threads with WD-40, kro-oil or similar a few days ahead of time. Repeat applications regularly. This will make the job go much smoother. Link to comment Share on other sites More sharing options...
sw Posted June 3, 2004 Share Posted June 3, 2004 so the vice was quite ok, thats good to know -study- Link to comment Share on other sites More sharing options...
kmgar99 Posted June 11, 2004 Share Posted June 11, 2004 Now that you did it and it worked out OK....I think i'll try it now. Did you get the correct bushings from AC? What were they called (terminology)? Link to comment Share on other sites More sharing options...
Guest Kopec Posted June 14, 2004 Share Posted June 14, 2004 The Bushings from AC are called "Trailing Arm" bushings. You will need 2 sets of 2 - to do both lower control arm bushings. To remove the old bushings (depending upon how damaged) drill a series of holes through the rubber, until the center bushing can be removed by tapping with a hammer. Once the center bushing is removed, saw (with hack saw) through the outer sleeve (of the bushing). Next, with a hammer and chisel, curl the sleve away from the control arm sleeve. A flat end chisel seemed to work well - without a low of effort. Link to comment Share on other sites More sharing options...
