Driveshaft Problem!
projekz
Well...I took apart the front and rear suspension to do my lift today and I completed everything really well. When I drove the truck out of the shop there was a pretty bad grinding/popping noise coming from the front right. I looks like the driveshaft is not sitting in the hub/flange properly and it's all crooked. Is there anything holding it in the flange that might've broken when I was swapping the suspension? Do I have to take the strut out again or can I go from the hub/drive flange to fix everything? Thanks
My passenger side driveshaft was broken at the outer cv joint. I replaced it in about 45 min. The fastest CV axle swap I've done so far!
Edited by projekz
