nmpath Posted July 4, 2007 Share Posted July 4, 2007 I finally got my AC lift installed but now there is a thumping noise coming from the rear end when I hit bumps. Is it possible that the springs are up side down? Any other ideas on what it might be? Thanks Link to comment Share on other sites More sharing options...
Pezzy Posted July 4, 2007 Share Posted July 4, 2007 Are you sure it's from the rear? Your front struts will top out over bumps for the first little while after the install. Link to comment Share on other sites More sharing options...
nissandoms47 Posted July 4, 2007 Share Posted July 4, 2007 Maybe your shocks arnt tight enough. Link to comment Share on other sites More sharing options...
nmpath Posted July 5, 2007 Author Share Posted July 5, 2007 It is coming from the rear for sure, ill check the shocks, thanks. Link to comment Share on other sites More sharing options...
denisb Posted July 5, 2007 Share Posted July 5, 2007 How much of a difference in height from stock? Could be the shocks are actually topping out (hitting their upmost extension) due to aftermarket shocks not being as long?!?!?!? Just thinking out loud.....don't mind the grinding noise or the burning smell Link to comment Share on other sites More sharing options...
