Noise From Rear End After Ac Lift Install?
nmpath
I finally got my AC lift installed but now there is a thumping noise coming from the rear end when I hit bumps. Is it possible that the springs are up side down? Any other ideas on what it might be? Thanks
Are you sure it's from the rear? Your front struts will top out over bumps for the first little while after the install.
How much of a difference in height from stock? Could be the shocks are actually topping out (hitting their upmost extension) due to aftermarket shocks not being as long?!?!?!? Just thinking out loud.....don't mind the grinding noise or the burning smell :crossedwires:
