Question About Shocks-forgive My Ignorance
ticker
I'm trying to order new procomp es3000 shocks and the Summit site only pulls up rear shocks for the 95. No pro-comp shocks are listed for the front. Whats the deal? I swear I saw them listed for the front on another site. Are the front shocks different from the rear on the wd21? If I get them ordered today I'll be able to install this weekend. :shrug:
Yes, they're different. The rears are dual eyelet, whereas the fronts have an eyelet on the bottom, and a threaded shaft to mount on the top. Not sure on part numbers, but I believe there's a thread on this. Search around for "Shock Part Numbers" and you should find a post by Cdhicks99 somewhere.
thanks simon. I did see that post about the part numbers, which actually made me more confused because the part number in the post is different than the part number recomended by summit. Also he only posted one number which I'm assuming is for the rear, Has anybody odered these for the all four corners?
Okay....stock length Pro comp part numbers....right from explorerprocomp.com
Front: 314518 Rear: 322500
Those are both for the ES3000 model shocks.
