dell1973 Posted May 30, 2007 Share Posted May 30, 2007 hi everyone its time for a lift.thinking about rough country uca and jgc coil.is there any hidden problems in doing the front that i should be aware of. i've read all the post on the board.i have a 90 se. thanks vince Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 31, 2007 Share Posted May 31, 2007 Not that I know of, but sometimes the UCA spindle bolts are real tight and hard to get out, particularly because they're so far inside the wheelwell. Sometimes they strip out on the way out too, but it's not common. Just remember that you'll more than likely need an alignment after you lift it. Link to comment Share on other sites More sharing options...
aries247 Posted May 31, 2007 Share Posted May 31, 2007 (edited) when cranking up the torsion bars watch to make sure you don't strip out the adjuster bolts like i did. yes both of them stripped. Edited May 31, 2007 by aries247 Link to comment Share on other sites More sharing options...
sammyb33 Posted May 31, 2007 Share Posted May 31, 2007 i still have my RC UCAs and Sway Away Torsion Bars for sale if you are interested........and i also have some JGC springs if you want them..... Link to comment Share on other sites More sharing options...
gillj Posted May 31, 2007 Share Posted May 31, 2007 Ill take them where are you and how much all that good stuff Im in arkansas 72702 zip Link to comment Share on other sites More sharing options...
dell1973 Posted May 31, 2007 Author Share Posted May 31, 2007 thankyou everyome for the info.will have pictures soon!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
