dmag23 Posted May 5, 2007 Share Posted May 5, 2007 So here's something else I could use some feedback on. I've noticed that the front hubs get pretty hot after a drive. This Pathfinder I'm overhauling had alot of miles so I've been slowly replacing things here and there. I replaced the front wheel bearings a while back and noticed that after driving for a short while (10 miles or so) that the locking hubs would be very hot to the touch. I took an IR thermometer reading and they typically show 170 degrees after a drive. I thought maybe the stock auto locking hubs might be the problem, and I wanted to switch to manual hubs anyway, so I put on some new Warn manual hubs. Still shows temps up to 170 degrees. The bearings are adjusted correctly; just tight enough to remove the wheel play but not so tight that the wheels don't spin freely. The calipers and brakes are new so I don't believe I'm generating excess heat from sticking brake pads. I know the hubs aren't locked and spinning the axles when in 2wd so that's not a problem. Does it sound like the hubs are running hot or is this a non-issue? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 5, 2007 Share Posted May 5, 2007 Sounds like heat transfer from the brakes. Hubs are usually warm after driving. Link to comment Share on other sites More sharing options...
jj big shoe Posted May 6, 2007 Share Posted May 6, 2007 ^^^That does sound like a heat xfer issue to me, too. Maybe the pads have to seat a bit since they're new. Are you what is referred to as a "spirited driver"? Maybe you could change your driving habits for a couple trips and see if it makes a difference. Link to comment Share on other sites More sharing options...
dmag23 Posted May 6, 2007 Author Share Posted May 6, 2007 No, I really don't drive it hard. Stick to the speed limit and take my time on stops. Ok, so it sounds like normal heat buid up. I'll write this one off as a non-issue. Thanks to you both for the feedback. Link to comment Share on other sites More sharing options...
McClurgM Posted May 6, 2007 Share Posted May 6, 2007 My hubs are warm after driving, but not overly hot. check the brakes, if nothing is wrong there....guess its normal. Matthew Link to comment Share on other sites More sharing options...
Precise1 Posted May 6, 2007 Share Posted May 6, 2007 Agreed, but still, it's worth 15 minutes to bleed the front brakes, just because. B Link to comment Share on other sites More sharing options...
