Msd Ignition Yay
88pathylove
I did not need a tach adapter, but the first gens do (As far as we’ve figured out) . Since your car can run without the tachometer working, just install the system by itself and if your tachometer doesn’t work, then order the part. My local performance store wanted $40 for the tach adapter, but truckperformance.com has them for $25. Call them up, the part is not on their website. Part # 8910EIS
I just did this mod not too long ago on mine (88 V6 Auto), it was pretty straightfoward and easy. Wiring was simple, it started up on the first attempt.
I did use the tach adaptor only because the tech at MSD noted my tach may not work. Everything works beautifully and i love it.
