88pathylove Posted April 30, 2007 Share Posted April 30, 2007 so just ordered the msd ignition and have been searching the forums and found that i might need a tach adaptor for my stock tach to work (i drive an 88 v6), so if any one knows of a link or something that would be great. Link to comment Share on other sites More sharing options...
NC95Pathfinder Posted April 30, 2007 Share Posted April 30, 2007 I did not need a tach adapter, but the first gens do (As far as we’ve figured out) . Since your car can run without the tachometer working, just install the system by itself and if your tachometer doesn’t work, then order the part. My local performance store wanted $40 for the tach adapter, but truckperformance.com has them for $25. Call them up, the part is not on their website. Part # 8910EIS Link to comment Share on other sites More sharing options...
88pathylove Posted April 30, 2007 Author Share Posted April 30, 2007 ok thanks and if any one has any other tips or tricks or has installed one before, tips? Link to comment Share on other sites More sharing options...
barthel Posted April 30, 2007 Share Posted April 30, 2007 88, I just did this mod not too long ago on mine (88 V6 Auto), it was pretty straightfoward and easy. Wiring was simple, it started up on the first attempt. I did use the tach adaptor only because the tech at MSD noted my tach may not work. Everything works beautifully and i love it. Link to comment Share on other sites More sharing options...
Precise1 Posted May 1, 2007 Share Posted May 1, 2007 I could swear there is a write up on this, inthe Garage/Tech forums I think. Did you try searching? B Link to comment Share on other sites More sharing options...
