Gunnison
I'm in Gunnison! I have a '97-'98 5spd with no mods to speak of, with the exception of some Baja lights and I rewired the fog light relay to draw power off the parking lights instead of the head lights. What would be some good entry level projects for as little $$ as possable? Any suggestions? If you guys are looking for some tough trails to test out your riggs check out the Crested Butte area.
The body lift made a huge difference in terms of the ammount of tire i can clear. $100.00
I will have removed my sway bars $0.00
New wheels with more back-spacing to reduce tire rub $160.00
there are a few.....
Matthew
Fort Collins
you wont be albe to do a body lift on this model, as its a uni-body, the only lift youll be able to get is out of suspension check out 4x4parts.com they have everything you could want for your ride. The first thing that i did was i got a pair of manual hubs, they run about $150 depending on where you get them. Next youll want to get some wheels with more backspacing. and then its up to you with what youll get next. Im sorry that you live there it must suck during the winter.
