What do I need for an AT-MT swap?
doughboy
I'm going to pick up my 5 speed Tuesday, and I need to know everything I will need to pull off the dead pathy. I know some of you have done it and would know, so any wisdom would be greatly appreciated
but to answer your question...
Transmission
Pedals (both brake and clutch)
Master Cylinder
All Fluid Lines
Slave Cylinder
(if you can get it get the tranny cross member out of the manual pathfinder its not needed, but i had to re drill holes to fit my auto cross member back on)
that is a basic list. PM milehighcowboy i believe somehow he got a complete listing from nissan every part that is needed, and he is currently doing his swap as well maybe he can point you in the right direction.
hey doughboy here is that list that sam is talking about. its a list me and a guy at the nissan dealership put together. its got a bunch of parts numbers that are no longer in use we were using a parts book form 1987 lol. but here ya go.
Clutch Pedal Bracket 46550-0W501- 1
Brake Pedal and Bracket 46501-0W000- 1
Clutch Master cylinder 30610-0W050- 1
Clutch to dampener line 30850-0W000- 1
Clutch Dampener bolts 08146-6162G- 2
Clutch Dampener 30660-0W000- 1
Clutch Dampener to passenger fender line 30851-1W200- 1
Brake/Clutch transfer block ???? 1
Transfer block to Slave Cylinder hose line 30851-1W211- 1
Slave Cylinder hose bracket 50915-0W010- 1
Slave Cylinder hose bracket bolt 08156-8161F- 1
Slave Cylinder hose clip 46206-2J000- 1
Slave Cylinder rubber hose 30855-0W010- 1
Slave Cylinder banjo bolt copper seals 46237-A4600- 2
Slave cylinder banjo bolt 46356-0E000- 1
Slave cylinder 30620-0W020- 1
Slave cylinder bolts 08121-0251E- 2
Driveline Parts
Clutch kit (clutch, pressure plate, throw out bearing) NU31214-1 (AutoZone part) 1
Throw out bearing support 30501-1C100- 1
throw out bearing control arm 30531-01S00- 1
throw out bearing control arm boot 30542-75P00- 1
transmission 32010-0W020- 1
transmission isolator (mount) bolts (bottom) 11258-D0101- 2
transmission isolator (mount) 11320-1W200- 1
Transmission bolts (top) 11393-0W000- 8
bell housing bolts M10 1.50 60-80mm 01121-06291- 8
Flywheel 12310-0W000- 1
Flywheel bolts M10 1.00 30mm 12315-D0210- 6
Pilot bearing 32202-B9500- 1
Transmission shifter 32839-62G00- 1
Transmission shifter knob 32865-50Y00- 1
Interior pieces
Inspection hole cover 74810-0W000- 1
Body to transfer case and transmission mount with boots 74967-0W020- 1
Outer rubber boot with mount 74910-0W010- 1
Finisher console with boot 96934-0W010- 1
Electronic pieces
ECM for Manual transmission 23710-1W600- 1
if you got any questions just shoot.
ben
got my five speed today... minus the clutch/brake pedal assembly the kid bought the truck to destroy and did just that... next step.... put it in... here comes the fun
