mygsris2slo4u Posted March 19, 2007 Share Posted March 19, 2007 I was in the woods friday night doin some wheeling and when I left I could notice a distinct clicking noise coming from my front passenger wheel... I thought it might be the hub not fully disengaging, so I repeatedly put it back in four wheel and out, but the problem still exists. The clicking stops when its in four wheel... Is my hub broken and needs replacement or is it hung up and can I do something to fix it? I've never had to deal with hubs before! HELP PLEASE!! :help: Link to comment Share on other sites More sharing options...
Gotrek Posted March 19, 2007 Share Posted March 19, 2007 The hubs disengage when you put it in 2wd and drive backwards 10ft or so. Did you drive backwards after taking of the 4wd? Link to comment Share on other sites More sharing options...
mygsris2slo4u Posted March 19, 2007 Author Share Posted March 19, 2007 yeah, I put it in reverse each time I was switching.... And I switched it in and out somewhere around 20 times to see if it would take it out Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 19, 2007 Share Posted March 19, 2007 Hubs are easy to take off and put back on. Pull 'em and see if anything broke inside. Link to comment Share on other sites More sharing options...
k9sar Posted March 19, 2007 Share Posted March 19, 2007 let us know if you need a diagram of the hub assembly. We have them for the 94/95 models Link to comment Share on other sites More sharing options...
mygsris2slo4u Posted March 19, 2007 Author Share Posted March 19, 2007 I took out the allens that hold the front of the hub on... To me nothing looked broken, but I have nothing to compare it to. A diagram would be great! Link to comment Share on other sites More sharing options...
glenn Posted March 19, 2007 Share Posted March 19, 2007 It could be anything that effects that half axel drive line Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 19, 2007 Share Posted March 19, 2007 does the 86-89 have manual hubs? I seen a couple of 87 and 89 at the JY that has manual hubs and was wondering if thats aftermarket or they do come with it originally. Link to comment Share on other sites More sharing options...
k9sar Posted March 19, 2007 Share Posted March 19, 2007 since it only clicks while NOT in 4WD, put that side up on a jack and turn the wheel by hand to see if you can isolate the noise. If it happened in 4WD, I would guess a CV joint about to go but you might just have something in your hub. I'll either post or PM you the hub exploded diagram for the 95. Link to comment Share on other sites More sharing options...
k9sar Posted March 19, 2007 Share Posted March 19, 2007 here Link to comment Share on other sites More sharing options...
denisb Posted March 19, 2007 Share Posted March 19, 2007 This is if you have auto hubs........ If you drive in 2wd and it clicks, when coming to a stop, does it clunck right before you get stopped? If so you probably have a sticking or bad hub clutch on the oposite side. Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 19, 2007 Share Posted March 19, 2007 I don't think many came with manual hubs, but manual hubs from a HB will bolt on if they're the same spline count. I've done it before! Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 20, 2007 Share Posted March 20, 2007 I don't think many came with manual hubs, but manual hubs from a HB will bolt on if they're the same spline count. I've done it before! so im assuming that the spline count on 86-89 would be 27 right? Is it even worth pulling it ? the reason im so eager to pull it out is to give me an idea how hard it would be to do it so in the future I know when I do mine Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 20, 2007 Share Posted March 20, 2007 i have also had my brake pad shims (from cheap ass advance auto parts) become un adhered and start hitting the hub bolts on the spindle... i say jack it up and spin it...and if im not mistaken it will engage while u spin...keep an eye on the cv to see if they''re locking or what Link to comment Share on other sites More sharing options...
