Gripenfelter Posted March 12, 2007 Author Share Posted March 12, 2007 Thanx for the info. Currently trying to find a reputable 350Z header manufacturer. Open to suggestions. Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 13, 2007 Author Share Posted March 13, 2007 So it looks like SS autochrome is mostly having problems with turbo headers. Obviously you need much thicker material or cast manifolds for a turbo setup. Regular headers aren't going to cut it. Link to comment Share on other sites More sharing options...
turbopath Posted March 13, 2007 Share Posted March 13, 2007 http://cgi.ebay.com/ebaymotors/OBX-EXHAUST...sspagenameZWDVW I know of about 10 people so far that have had good luck with obx headers. If you extend the wires, you need to use shielded/larger wire and a pair of weatherpack connectors and it will be fine. I'd personally still run a pair of high flow cats down low to be in compliance with federal regulation. (They don't really kill power anyway) Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 13, 2007 Author Share Posted March 13, 2007 I was looking at these: http://cgi.ebay.com/ebaymotors/Stainless-S...091065222QQrdZ1 or http://cgi.ebay.com/ebaymotors/Nissan-350Z...101030362QQrdZ1 I know the y-pipe won't fit but I can use the downpipes if they have cats. Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 14, 2007 Author Share Posted March 14, 2007 (edited) Ignore the above post. Neither of those will work. I was under the truck last night and took some measurements. The key to finding a header that will fit is to look for ones that hug the block, have an outlet that points downward (45 degrees preferred), and have a short overall length so as not to interfere with the transmission tunnel/firewall. That being said, I found a short block hugging set of headers that should fit. They are a no name brand off ebay. Just ordered them. Should have them in about 2 weeks and then off to the exhaust shop. Edited March 14, 2007 by Gripenfelter Link to comment Share on other sites More sharing options...
Jarsiff Posted March 15, 2007 Share Posted March 15, 2007 Ive been wondering about this for a while, definately interested in the results and the pictures Link to comment Share on other sites More sharing options...
