tow hook bolt size?
LD50
You know I just put a second one on a few weeks ago too :shrug:
But I would suggest that you just remove one from the otherside and take it in with you, that way to know for sure that you get the exact bolt you need :aok:
are they the same as ours? i dunno for sure although the X ones fit my truck so they probably will the r50 too. let me look as i had to look for a couple here a while back. actually, they are hard to find in the correct hardness so the best bet would be to get a couple in the j/y.
here is what's on my truck: M12, 1.25, 50mm they are grade 7 (metric) which is really a 10.9 in the english grading system. good luck. i finally was able to find mine at a mercedes repair shop. nissan wanted an arm and a leg and a pint of blood too. :D
