barthel Posted March 1, 2007 Share Posted March 1, 2007 ...in a never ending series. I just got my oil filter relocation kit and am having a few issues with where to mount the filter base, nowhere seems to be a really good place to put it (although the oil filter is HUGE). Even with a smaller filter, it's gonna be tight. Are there any issues or problems if I mount the base horizontally rather than vertically? If I can turn it on it's side, the I can fab a bracket real easy coming off the fuel filter bracket. As usual, I thought I'd ask the pros. :bow: Link to comment Share on other sites More sharing options...
RedPath88 Posted March 2, 2007 Share Posted March 2, 2007 Dual or single? Here is a pic of where I mounted my Dual kit Ad here is how Filthy Lurker did his Be both used the same location but went about it differently in regard to the brackets we made. EDIT 07/03/2009: Two pic fixed and two more added, Note that the zip ties were temporary and have since been removed. This was to stop a leak that developed between the hoses and barb fittings Link to comment Share on other sites More sharing options...
barthel Posted March 2, 2007 Author Share Posted March 2, 2007 It's a single. Where did you move the relays and fuse links on the PS fender wall. Right now, I'm leaning toward moving the fuel filter back toward the firewall and fabbing a bracket to attach to the old fuel filter location. I'm definitely getting 90 degree fittings. They come out of the top now and I think that's part of my issue. Link to comment Share on other sites More sharing options...
RedPath88 Posted March 2, 2007 Share Posted March 2, 2007 I never moved them, the bracket that I made stands to the inside of the relay housing *meaning the relay box is in its stock location and is between the inner fenderwell and the oil relo Link to comment Share on other sites More sharing options...
mws Posted March 2, 2007 Share Posted March 2, 2007 Depending on how much fabbing you want to do.... I bent and welded a bracket that bolts to the firewall, side wall, and top of fender liner. On this bracket is the oil filter and all the auxiliary relays and fuse blocks... I had a photo somewhere... can't find it right now.... Link to comment Share on other sites More sharing options...
barthel Posted March 4, 2007 Author Share Posted March 4, 2007 Red, Thanks man, those pics were a BIG help. Link to comment Share on other sites More sharing options...
Slick Posted March 4, 2007 Share Posted March 4, 2007 my set up Link to comment Share on other sites More sharing options...
barthel Posted March 4, 2007 Author Share Posted March 4, 2007 Sweet Slick! I'm going to do something similar. Same location, mounted vertically. I found some 3/8 NPT 90 degree adapters at the hardware store that will solve my top clearence issues. Thanks all, you've been a BIG help. Link to comment Share on other sites More sharing options...
xkrewx Posted March 27, 2007 Share Posted March 27, 2007 sorry to start this one back up again...... where can i find a oil relocation for a 1996....? Link to comment Share on other sites More sharing options...
xkrewx Posted March 28, 2007 Share Posted March 28, 2007 (edited) would this fit my 96? http://www.alamomotorsports.com/pmc/Cat_page27.html any info would really help alot....i really want to relocate the oil filter and put a double in Edited March 28, 2007 by xkrewx Link to comment Share on other sites More sharing options...
jj big shoe Posted March 28, 2007 Share Posted March 28, 2007 That should fit. Mine's a Trans-dapt, but it looks the same as the Perma-cool in the photo and takes the same Fram PH8A filter. Link to comment Share on other sites More sharing options...
barthel Posted March 28, 2007 Author Share Posted March 28, 2007 Well, it's over and done! Thanks to everyone for the excellent ideas. Link to comment Share on other sites More sharing options...
Pezzy Posted March 28, 2007 Share Posted March 28, 2007 would this fit my 96? http://www.alamomotorsports.com/pmc/Cat_page27.html any info would really help alot....i really want to relocate the oil filter and put a double in see this thread: http://www.nissanpathfinders.net/forum/index.php?showtopic=13782&hl= Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 28, 2007 Share Posted March 28, 2007 (edited) Looks great Bart :cool2: I like that clean install.That reservoir looks purrrrrdy too I bet your valve covers are the same color wish theyd make teflon tape in clear or transparent Edited March 28, 2007 by SuperSon Link to comment Share on other sites More sharing options...
RedPath88 Posted March 28, 2007 Share Posted March 28, 2007 wish theyd make teflon tape in clear or transparent Just pull the excess off -thnkboutit- Link to comment Share on other sites More sharing options...
barthel Posted March 29, 2007 Author Share Posted March 29, 2007 I bet your valve covers are the same color Nope. At least not yet. But I did paint the timing covers and the air cleaner when I did the timing belt. Link to comment Share on other sites More sharing options...
