Question for Mr. Jim
I'm looking at buying the ARW Atlas wheels for my 95 SE like the ones on your pathy. Right now it is not lifted any. I have 31x10.50 tires on the stock rims.
If I put the same tires on the Atlas 15x8's will they fit and turn in the wheel wells or should I get the 15x7's? I plan on putting a 3" suspension lift on later but I want the new wheels now.
Can I get them to fit if I crank my torsion bars some?
The offset is what you need to worry about, not the width of the wheel. Well, unless you wanted to use a 10" or wider rim, I suppose. 7" wheels work fine anyway, you won't NEED 8" rims unless you want to go to a 12.50 or wider tire.
I'm running 8" wheels and they fit just fine. It's all about the backspacing. Keep it close to stock and you'll be fine. Cranking up the t-bars a little bit is a good idea just to level it out and keep things nice and steady.
