Jmax5000 Posted February 15, 2007 Share Posted February 15, 2007 Recently i noticed that my frond end sits like this- /---\ I know I need a new center link, but there has to be more to it. Possibly ball joints? Thanks Link to comment Share on other sites More sharing options...
mws Posted February 15, 2007 Share Posted February 15, 2007 That's the view from the front, right? Let me guess, stock UCA's, right? The camber change is due to the suspension lift. Rough Country UCA's will correct most of it. Link to comment Share on other sites More sharing options...
Simon Posted February 16, 2007 Share Posted February 16, 2007 Even at stock height, though, it will do that if the CL is shot. Mine did. Definitely though, get it replaced (go with L&..you'll never have to buy another one) and get it aligned. Also, check your upper ball joints, and tie-rods for play. Link to comment Share on other sites More sharing options...
Jmax5000 Posted February 16, 2007 Author Share Posted February 16, 2007 No i don't still have the stock uca's-- I have the Rancho ones.... and my tie-rods seem to be fine, how long a job is it to replace my ball joints? is there any special tools i might need? And how long should it take? thanks for the input... its appreciated Link to comment Share on other sites More sharing options...
Simon Posted February 16, 2007 Share Posted February 16, 2007 Upper ball joints are pretty easy. You may need a ball-joint puller, or pickle fork to get them out of the spindle. Really, should be an hour job, for both sides. Sometimes, tapping on the side of the spindle where the ball joint goes through will help loosen them up.....but I always use a ball joint puller. Link to comment Share on other sites More sharing options...
