GrnMchn Posted February 4, 2007 Share Posted February 4, 2007 The SES light is on my 01' pathfinder has come on and I pulled codes P0160 & P0158. They are (No activity bank 2 sensor 2) and (High voltage bank 2 sensor 2). My question is will replacing the bad 02 sensor fix both codes or did something else kill the 02 sensor? Also which 02 sensor is the bank2 #2 sensor? I am guessing I just need to replace the 02 sensor but I don't know which one. Link to comment Share on other sites More sharing options...
GrnMchn Posted February 7, 2007 Author Share Posted February 7, 2007 Does anyone have a diagram of the exhaust system so I know which sensor is the bank 2 number 2? Link to comment Share on other sites More sharing options...
nissandoms47 Posted February 7, 2007 Share Posted February 7, 2007 drivers side rear 02 sensor is bank 2 sensor 2. Link to comment Share on other sites More sharing options...
GrnMchn Posted February 8, 2007 Author Share Posted February 8, 2007 drivers side rear 02 sensor is bank 2 sensor 2. THANKS! Link to comment Share on other sites More sharing options...
vengeful Posted February 8, 2007 Share Posted February 8, 2007 And yes....those two codes together are descriptive of a faulty sensor. There's no way that the same sensor can spit out nothing, and then higher than normal voltage levels with an engine that is running well. Link to comment Share on other sites More sharing options...
lyzic Posted November 14, 2009 Share Posted November 14, 2009 Just wondering if replacing the sensor fixed this problem for you, as I just had my Pathy do the exact same thing! Cheers Link to comment Share on other sites More sharing options...
