how much can i put on my electrical system?
iLLlegal
ok so im trying to find an amp for my sub and i might have one but i need to know
how many watts i can hmm "safely" pull off. im going to do the big 3 before i
install the amp but im just wondering.
I know it wont be able to handle the 2000-3000watts i need to run my sub
mabey 1000watts?
thx
I have a 1000 watt amp, just make sure that you install an in-line fuse between the battery and amp. When mine is cranked up high, the headlights flicker to the beat a little, thats all. You caould get a bigger amp and install a capacitor.
hmm. thanks ya ill prolly get a cap dunno if i can find a quest alt anywhere
around here thoough. the amps more like 1200watts we'll see how she holds
FWI... Mercury Villager's are the same as a Quest (gives you a little more to look for) ;)
