87pathfinder4banger Posted May 8, 2004 Share Posted May 8, 2004 does anyone know of any cheap or used electric fans for a z24 motor?? i'm on my third water pump in 1 1/2 years because my fan clutch keeps seizing. i've been told that a seized fan clutch can rob the truck of 20-30 horsepower, which for a 4 cyl. is a big deal. but obviously something is wrong with mine because i wouldnt need three of them. if anyone could help it'd be great. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 8, 2004 Share Posted May 8, 2004 More like 2 or 3 horsepower, man. Whoever told you that wasn't informed very well if you ask me. If the Pathy with the Z24 uses the same radiator as a V6, then a Nissan Quest or Mercury Villager 16.5" fan will work great, it just pulls a lot of amps to run it. You'll just have to look around and see what will fit and what you can afford. Link to comment Share on other sites More sharing options...
87pathfinder4banger Posted May 8, 2004 Author Share Posted May 8, 2004 yeah, i dunno how informed he was. he had a 87 4runner and said the same thing happened to him and he had it dyno'ed and that was what it showed up as. he's a heavy duty mechanic and knows way more about vehicles than i do anyways Link to comment Share on other sites More sharing options...
87pathfinder4banger Posted May 8, 2004 Author Share Posted May 8, 2004 any idea on costs?? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 8, 2004 Share Posted May 8, 2004 That guy must have either owned a dyno or worked for the place that had one, cause those things are expensive as hell to just run tests on. I got my Quest fan off Ebay for $10, the junkyard wanted $50-$75 for one, and new they're like $375. A replacement 16" fan like Jim has on his Pathfinder is about $100-$125 plus a electric thermostat to control the fan for another $20 or so. Install it yourself and save even more! Link to comment Share on other sites More sharing options...
