perri91 Posted January 10, 2007 Share Posted January 10, 2007 well i have this button in my 91 it says inter-lock im thinkin its locking diffs but i dont know if anyone knows just get back to me thanx Link to comment Share on other sites More sharing options...
packie88 Posted January 10, 2007 Share Posted January 10, 2007 ohhh how we all wish it was for locking diffs. im assuming you have a manual transmission. it just locks it so it cant be started if i am correct. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted January 10, 2007 Share Posted January 10, 2007 (edited) Actually, it allows you to start the engine without pushing in the clutch. Its best to be done in neutral. Just turn the ignition on, push the button, then start the engine. Oh, and yes, you will move if its in gear. Edited January 10, 2007 by 5523Pathfinder Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 10, 2007 Share Posted January 10, 2007 Oh, and yes, you will move if its in gear. im still waiting on that story of i hit something...i pulled mine on the street and for some reason hit that button and tried to turn it over and she jumped fwd bucked and off we went...if u hit it while the truck is on it makes the dash light up like a xmas tree IIRC... Link to comment Share on other sites More sharing options...
mws Posted January 10, 2007 Share Posted January 10, 2007 Very handy if you're in a very tough spot off roading and find it hard to get started without spinning or stalling. Put 'er in 4W Lo and 1st gear with the engine off, and then activate the starter (yes, with the clutch engaged). You will very slowly and smoothly start creeping forward, hopefully smooth enough to get enough momentum keep moving after the engine catches. Don't use for more than a couple/few seconds at a time, as the starter has to work extra hard and will heat up quickly. And is drawing a huge amount of current. Link to comment Share on other sites More sharing options...
perri91 Posted January 11, 2007 Author Share Posted January 11, 2007 well thanx cause i know the new nissans have it like the titan and stuff and i thought maybe it was the same i was afraid to push it cause i was afraid something bad was goin to happen but yea the story of hittin something my car slipped out of gear and roled into a tree Link to comment Share on other sites More sharing options...
packie88 Posted January 12, 2007 Share Posted January 12, 2007 well i tried to pretend like i knew something but failed Link to comment Share on other sites More sharing options...
5523Pathfinder Posted January 13, 2007 Share Posted January 13, 2007 well i tried to pretend like i knew something but failed Dont worry, we still like you! Link to comment Share on other sites More sharing options...
