Elkman Posted December 27, 2006 Share Posted December 27, 2006 When I bought my 95 Pathfinder a couple of weeks ago, the seller said the cruise worked, but doesn't. The switch on the dash lights up when turned on, but nothing happens when I touch the set on the steering wheel. Is there a fuse somewhere I need to check? All the fuses under the dash are good. Thanks Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 28, 2006 Share Posted December 28, 2006 Check to make sure the vaccuum line on the CC diaphragm under the hood is still plugged in and intact with no leaks. There is a CC module inside, I forget where though. Back end under the rear window on the driver's side, I think? Link to comment Share on other sites More sharing options...
govols74n Posted December 28, 2006 Share Posted December 28, 2006 I'm checking mine today when I install my fog lights....tired of not being able to see deer coming at me, and cant use the dang off road lights, they are too bright for the roads thats for sure. Link to comment Share on other sites More sharing options...
k9sar Posted December 28, 2006 Share Posted December 28, 2006 mine didn't work after the shop repaired the fender damage. Turns out that they didn't have the hose from the CC pump to the diaphragm connected. Link to comment Share on other sites More sharing options...
govols74n Posted December 28, 2006 Share Posted December 28, 2006 Well, checked the infamous vaccuum line on the cc, it was torn on the end and loose so i cut the end off and put it on. Nice and snug, but still doesn't work. I'm on my wat to the parts store to get a new hose, it looks pretty dry-rotted......CROSS YOUR FINGERS 4 ME!! (I could care less about the cruise, lol, just bored during my holiday time off....can't hit the trails till I get my CV boots fixed -alcohol- pssd Link to comment Share on other sites More sharing options...
mws Posted December 28, 2006 Share Posted December 28, 2006 Hmmmm... if that hose is dry rotted, you should consider replacing ALL of the original hoses under the hood. Perchance has your pathy spent some time parked in a garage in which there is a refrigerator or freezer? Refrigeration compressors generate ozone which accelerates the degradation of rubber. Link to comment Share on other sites More sharing options...
govols74n Posted January 7, 2007 Share Posted January 7, 2007 (edited) Nah, my hoses are all fine, just that one... of course someone else may have replaced them. I've only owned it for a year and a half or so. Edited January 7, 2007 by govols74n Link to comment Share on other sites More sharing options...
