Alarm/Security Disable, Please Help!
Orangetang
Tried a lot of searches and only found the thread about resetting the immobilizer, so....
OKAY, I need to disable my alarm completely. I replaced my signal flasher unit today with a none Nissan one, (1/5th the cost) and my alarm has been gone off on its own (factory system) twice at random times, several hours later. I"m going to go outside and see if there is a fuse to pull, but please post something if you have any ideas. This is brutal!
The Thread explaining my signal issue....
Thoughts... My hood wasn't latched down all the way, so that was probably setting it off, since it's storming outside right now (4am...). I couldn't find any alarm/security relay or fuses, so i pulled the horn relay AND fuse, then set off the alarm. At least its quiet now if it does go off....
Could my NAPA blinker switch cause this, or was it probably just the hood? Everything seems to work otherwise.
