Terrible gas mileage
Lunartic
What would be the cause of me loosing about 80 miles/tank of gasoline. Its really wierd but would a bad O2 sensor be the cause? How do I go about checking or testing this device?
:help: This is already bad on gas, but 400k to a tank??? What happened?
winter fuel... perhaps.
very possible. I know here, I have lost some mileage do to using the defroster, heater, wipers, stereo, rear defroster and god knows what else at the same time. Seriously, using the defroster is just like having the A/C on.
I will be doing a code check later today for sure. As for the defroster and A/C. When I turn the lever to the defroster the A/C does not turn on. Mine only turns on when I press the A/C button in and the green light comes on and the engine will lag a little, but only then does the compressor run.
