RI_ChevyGuy85 Posted October 11, 2006 Share Posted October 11, 2006 god i wish i had crank windows. as of right now the only window that works is my driver's side front. when i hit the button to move it, i get a clicking side from near speaker panel on passenger door. any ideas? all elec locks work, just not the windows. Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 12, 2006 Share Posted October 12, 2006 The master window switch tends to fail on these. Tried swapping it for another from a junkyard? Do the windows work individually with their own switch or no? Link to comment Share on other sites More sharing options...
perri91 Posted October 12, 2006 Share Posted October 12, 2006 idk but i know my driver rear doesnt come back up and i have a wedge holdin it upp so it doesnt fall down Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 12, 2006 Share Posted October 12, 2006 Pull the door panel and take a look inside. You'll figure it out if you can see what's broken. Link to comment Share on other sites More sharing options...
RI_ChevyGuy85 Posted October 12, 2006 Author Share Posted October 12, 2006 The master window switch tends to fail on these. Tried swapping it for another from a junkyard? Do the windows work individually with their own switch or no? 88path, nah the windows don't work on their own switches either unfortunately. only one that actually does anything is the driver's Link to comment Share on other sites More sharing options...
RI_ChevyGuy85 Posted October 12, 2006 Author Share Posted October 12, 2006 88path, nah the windows don't work on their own switches either unfortunately. only one that actually does anything is the driver's and i did pull the door apart, checked the wires and everything they all look good. cleaned the ports too, still nothin Link to comment Share on other sites More sharing options...
k9sar Posted October 12, 2006 Share Posted October 12, 2006 I recently pulled a window motor apart and cleaned the excess carbon dust from the coils and reseated the brushes. works like a champ now. Link to comment Share on other sites More sharing options...
RI_ChevyGuy85 Posted October 16, 2006 Author Share Posted October 16, 2006 after ripping everything apart and putting it back together over and over again, i found that it helps to depress the so called "window lock" button. this will enable you to use all of the windows. i think i drink too much. Link to comment Share on other sites More sharing options...
Simon Posted October 16, 2006 Share Posted October 16, 2006 LMFAO!! Well done, Grasshopper!!! Link to comment Share on other sites More sharing options...
govols74n Posted October 20, 2006 Share Posted October 20, 2006 after ripping everything apart and putting it back together over and over again, i found that it helps to depress the so called "window lock" button. this will enable you to use all of the windows. i think i drink too much. HOLY SH_T BATMAN.....I wouldn't have told on myself like that!!!! (major loss of cool points.) Link to comment Share on other sites More sharing options...
