WRL69 Posted October 24, 2006 Author Share Posted October 24, 2006 (edited) That's right where the catalytic converter is. Perhaps it's missing a heat shield. Could you attach pic where I can look that heat shield? My mech tell me is all good ? Regards, Edited October 24, 2006 by WRL69 Link to comment Share on other sites More sharing options...
RedPath88 Posted October 24, 2006 Share Posted October 24, 2006 There are two of them, one on the truck.. you should see a sheet of metal attached to the bottom of the body directly above the exhaust pipe/CAT. There is also one on the cat (not likely to be missing) it is just a metal sheild that surrounds the CAT. Both should be pretty obvious if they are or are not there Link to comment Share on other sites More sharing options...
