statikuz Posted April 23, 2004 Share Posted April 23, 2004 Hey, this is another question from the place where all easy questions come from. =) I was toolin' around under the hood of my Pathy today and noticed all the fluid in the coolant reservoir, y'kno over to the left of the radiator was pretty dirty-lookin'. Should I worry about this? How do you drain/replace it? Is it hard? =) Thanks! Link to comment Share on other sites More sharing options...
sw Posted April 23, 2004 Share Posted April 23, 2004 check the radiator, see what colour the coolant is in there - should be green as for the over flow bottle unscrew it, take it out and wash it out till its clean did this with mine Link to comment Share on other sites More sharing options...
denisb Posted April 23, 2004 Share Posted April 23, 2004 Sometimes if you use leak seal products it will give your coolant a look similar to having oil in your coolant. Link to comment Share on other sites More sharing options...
statikuz Posted April 23, 2004 Author Share Posted April 23, 2004 Yep, the coolant in the radiator was green, but the overflow bottle was SUPER-dirty... took it out and cleaned it and filled it up with new coolant... took all of about 15 minutes. =) Link to comment Share on other sites More sharing options...
