BUMPER MESURMENTS
SUCK CREEK OFFROAD
no bumper and im at work fabing one up
ah ah! fab me one up n i'll give you the measurements.. hehehe.... gimme a bit n i can get you the measurements ;)
oh yeah. you REALLY don't want to use the stock mounts anyway.... they are uber flimsy
Edited by Slick
The inside dimension of where the bumper bends is 60", that leaves about 3/4" gap per side. The bumper L brackets are 29" apart (inside dim) with the bolt spacing at 32" and 38" apart. That should give you what need.
I guessing this bumper is mainly for cosmetics, as Slick pointed out, the mounting brackets are pretty weak.
thanks for the help. Ive been waiting all morning to get these measurments.Ive got an 87 pathfinder with good bumpers, just fabing up some off road bumper. Also if any body knows were i can get a 3.0 engine in good shape let me know.Mine has a spun bearing.Mine is the throttle body type not fuelinjection and does any one know what year models will enterchange with this one. Thanks again.
your block is the same.. it's the intake that is different and wiring. if you can find a good VG30 block then you're in luck. that's 87-95 that share the same block. in 90 they started the VG30E's ;)
In that case, I'd build off of the two holes (per side) in the frame horns underneath used for grill guards !! If you want I can give you that info also, the sun is comming out... :D
Slick is basically right. I believe there is a little bit of difference (a tapped hole or two) but basically interchangable. lgranch might have one. Try looking through the parts for sale section or posting in the parts wanted section. Make sure to state where you are.
