Pathfinder02 Posted August 29, 2006 Share Posted August 29, 2006 I have a 1992 Path and I am going to put new carpet in it. Does anyone have any reliable ref. Link to comment Share on other sites More sharing options...
jj big shoe Posted August 29, 2006 Share Posted August 29, 2006 (edited) I got some for the passenger area of my 87 from some ebay shop for about $100. Its supposed to come "molded" to fit but not much. It works fine, just don't expect it to drop right in. You'll have to work it a bit. Also make sure to clean the floor pan as good as you can for best results. For the rear I got some grey indoor/outdoor rubber backed carpet from Home Depot for about $30 and cut it to fit. It looks good and is cheap enough not to worry what I throw in back. Edited August 29, 2006 by jj big shoe Link to comment Share on other sites More sharing options...
FLApathy Posted August 29, 2006 Share Posted August 29, 2006 Here Here I hear they do good work, and welcome to the boards! Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 29, 2006 Share Posted August 29, 2006 i've got some carpet out of my 87 and some out of another members 95 the 87 is blue and the 95 is grey it could use some cleaning depending on y ure changing ures...im going to try to do some diamond plate and rhino liner or line x... Welcome aboard Link to comment Share on other sites More sharing options...
RedPath88 Posted August 29, 2006 Share Posted August 29, 2006 Welcome to the boards Link to comment Share on other sites More sharing options...
FLApathy Posted August 29, 2006 Share Posted August 29, 2006 (edited) The Timing Belt will hurt more. Ok wrong thread. But will we're at it, whens the last time yours was change? Edited August 29, 2006 by FLApathy Link to comment Share on other sites More sharing options...
Pathfinder02 Posted August 30, 2006 Author Share Posted August 30, 2006 I just replaced my timing belt and w/p, seals etc. last month Link to comment Share on other sites More sharing options...
Pathfinder02 Posted August 30, 2006 Author Share Posted August 30, 2006 Thanks everybody for the info Link to comment Share on other sites More sharing options...
