alternator
glenn
Any thoughts on how to add a second alternator? I was thinking of getting an alternator/ welder unit and figured adding it as a second unit would give me a backup for the first and increase the overall power for winching. Any advice or a point in right direction would be appreciated ! :shrug: THANKS --glenn
Edited by glenn
thanks, but in S.Cal I need the AC. I wanted to run 2 different alts so that I would have a back-up if one went out. Any other ideas would be appreciated. THANKS ! -glenn
Ya there is no room HA! If you can part with that AC it would make it way easier. I just took mine out 2 days ago. Its quick, easy, and now I think this will light a fire under my a** to get a Quest alt and put it there.
Rami
You would need to fabricate new brackets, cut a big hole in the hood, and use a muuuuuuch longer drive belt...
I would go with a high output alternator in stock location and carry the stocker as a spare.
