lee_cha_nin Posted August 7, 2006 Share Posted August 7, 2006 Hi, what are do's/dont's if the engine is stalled while driving (automatic transmission)? I would: 1. Switch the selector to N 2. restart the engine if it fails then: 1. Depending on a traffic and conditions a) depress the brake pedal and when it loses pressure in cylinders start using manual brake or ...(fill in, please) Nick Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 7, 2006 Share Posted August 7, 2006 Pull over first using the brakes as you normally would. Shift to neutral and try to restart. The brakes will still be useable, but the pedal pressure required goes up a bit. Link to comment Share on other sites More sharing options...
lee_cha_nin Posted August 7, 2006 Author Share Posted August 7, 2006 (edited) OK, I was not sure if the brakes would function at all. So it is just "power" part that goes off in such a case Edited August 7, 2006 by lee_cha_nin Link to comment Share on other sites More sharing options...
Precise1 Posted August 8, 2006 Share Posted August 8, 2006 Yes, they will still function somewhat but you have to press hard and don't expect to be able to lock up the tires. If you need extra help, use the parking brake also. The engine shouldn't die while it's driving, so I recommend coasting to the side of the road as quickly as is safe, stopping and then try to restart or determine what the problem is... B Link to comment Share on other sites More sharing options...
govols74n Posted August 9, 2006 Share Posted August 9, 2006 WOW :confused: Link to comment Share on other sites More sharing options...
Dave_C Posted August 9, 2006 Share Posted August 9, 2006 If it does stall while driving, don't do a panic mode and turn the key off and try to turn it back on again while trying to come to a stop...you risk your steering wheel locking, then you could be potentially "screwed". Link to comment Share on other sites More sharing options...
