tdz77
About tdz77
  • Birthday 01/01/1977
    3" Suspension lift
    Screwdriver Mechanic
    Rarely Go Off-Road
    Terrano R3m
Contact Methods
  • Website URL
    http://
  • ICQ
    Europe/Poland
tdz77's Achievements
  1. It sounds like fuel check valve is loosing its function. Check out this item (it should vibrate when you hear this sound): I have same issue from about two years, but it doesn't do anything else other then "farting" from time to time (especially a minute after turning off engine) so I don't bother. People say that if this valve is broken, it may cause long cranking times when starting (fuel line looses pressure), but in my case it is not happening (starts normally). I think it is on evaporation tube - so it does not have to do with fuel line pressure, but it releases pressure from fuel tank. Regards, TD
  2. Your problem is connected with the lock of tailgate (in this lock is located the switch that turn off interior lights). You should regulate the bolt on the floor, or inspect the lock itself.
  3. Hi, Can You can read Russian? Don't bother I cant, but I found something that can be useful for You (there isn't much reading necessary ). Look here : http://www.nissan-4x4.ru/Razdeluy/Sdelay_s...&opencat=73 These plans are for Terrano I front bumper (the same as Pathfinder I - WD21) Regards
