Nufy
Nufy last won the day on May 28 2025
Nufy had the most liked content!
    1995 Pathfinder XE LSD, Front factory Diff Skid Plate. Warn Premium Hubs Spicer Tie Rod ends sitting in a box waiting to be installed. Costco Child Seat. Going to 31's soon........
    Choose
Contact Methods
  • Website URL
    http://
  • ICQ
Nufy's Achievements
  1. You and me both.... tap Tap Tap tap tap tap tap tap........... It goes on and on for a couple minutes in the morning. I just turn up my new Mp3 player a bit more....LOL
  2. Nufy
    Gas Smell
    I already looked at that and tightened them a while back when I first read about it. Maybe I'll give er another twist of the screwdriver. Or just replace it. It can't be that expensive... Right ?????
  3. Nufy
    Gas Smell
    Lately i have been noticing a strong smell of gas when I start my Pathy in the mornings. Usually more noticable on cooler mornings. Starts and idles fine. Power like it always has had. Just wondering where to start looking for causes. O2 sensor ???? Oh btw 95 Pathy XE 5 spd 184,000 kms
  4. Nufy
    cv boot replacement
    Take the axles off. Its really not that hard and the split one's aren't all that reliable. (So I've heard) Remove the tire (after supporting on a stand) Remove the hub assembly and unbolt the axel from the T-case. (12 pt 12 mil metric socket required 3 - 4 bux at Sears) Unbolt the shock bottom and push aside. Crank the Steering Wheel all the way to the left. Should give you good access to the shaft. With the shock out of the way you should be able to slide the axle out of the wheel housing. Then you can replace the boot on a bench where it will be much easier. That was a quick summary of what I did when I did mine a few months back. I'm sure someone else will chime in if I missed anything. Good Luck.
  5. I had to get mine for a lubricant dealer here in Calgary. Call around to see who carries it and then get the bets price. If there is a local rep in ON I bought mine from Boss Lubricants in Calgary. I got a 20 litre bucket for about 100 bucks. Way cheaper then synthetic per litre from the parts stores. If you can find one that carries it. Just my .02.
  6. I thought it was all or some of those as well on mine. Turns out I had/have a broken exhaust mount in the backl an dit was llowing it to bang on my running boards. I removed the boards and the knocking went away. Try the simple stuff first.
  7. Check out the host site for this forum. (Look up to the blue banner) It has a good comparison of the different model years and trim packages I think.
  8. I got mine on ebay. 60 US for a set. Direct replacement.
  9. I actually did mine from underneath so the battery didn't come into play at all. It was a real PITA trying to get the new one all lined up by myself but I got it. But to each their own.
  10. Why remove the battery ?? Disconnect yes but why remove..
  11. Maybe this thread can be cleaned up and pasted at the top with the other Important topics.
  12. Great Write-up. I never would've thought of bringing it out over the Centerlink. I just did mine in about 3 hours including Oil change. Now I just gotta bring the old one back for the core charge. Cheers :cool2:
  13. TXS for the free no commitment info. I'm on holidays for he next week or so but I'll pull it when I get a chance and clean it up a bit.
  14. OK, 95 Pathy XE 5Spd V6 Had a problem with the starter on my Pathy last week. Pathy had started fine since I bought it, but one day last week I went to start it and no go. Not even a click for the solenoid. Pushed it to jump it and it started fine. Drove it home and it started with the key a bunch of times. Went on some errands and again it started fine. Came back home and parked in the garage, tried it one more time and no go. Not even a click. Grabbed a metal rod and tapped the starter a few time and it started A-OK again. That night I pressure sprayed all around the starter to clear out some of te gunk that had collected in anticipation of having to swap it out. Has been working fine ever since. Any ideas / suggestions what to look for incase it happens again ?? I'm not concerned for myself as I can always jump start it to get it home but the wife is driving it occasionally and I wouldn't want her to get caught with my kids in the car. TXS in advance.
  15. If they don't work, Just stick em on your tranny and oil pan to collect shavings.
