About burton8it
- Birthday 01/24/1985
its a 92 xe 5 speed bought her for 2500 bucks and she has been good to us for almost a year now. still starting off and going a bit at a time but she's a tank and doesn't seem to want to stop. she's most for surely part of the family now
Skilled/Experienced Mechanic
1992
Contact Methods
MSN
viper_rt16@hotmail.com
Gender
Edmonton AB
burton8it's Achievements
NPORA Regular (2/5)
It may not be your alternator that's the problem buddy had something similar happen to his and he replaced everything battery, alternator, etc. It actually landed up being a bad ground which cause the issues. He replaced his cables and worked wonders
hey i'm from edmonton looking for nissans to come out and play
Took me about 6 hours to do mine and my 31's fit perfect now almost look to small lol
left side drivers side
HMMM i'll double check the brake booster. Cause we just replaced the engine and replaced every thing that needed to go on it
any...anything better than haynes repair manual ?
burton8it replied to Pinip's topic in 90-95 WD21 Pathfinders
yuppers search is great. i'll stick to having the c.d. copy though laptop sits perfect on top of the engine -
So my 92 XE about two weeks ago has been starting to whistle at me. The problem is at cold start up you can hear a very high pitched whistle coming from the engine compartment. Also when you are coming to a stop the RPM's will stay at around 1800 for a frew seconds once stoped then slowly go back to regular idle. I've checked all my hoses and can not find a leak anywhere. Any words from the wise may help me find the mystery whistle.????
Sweet deals thanks man -
I have the C.D. copy of the original WD21 service manual if you need a copy send a pm -
I just put a 3" body lift in my 92 XE this weekend and had no problems with the shifters. Is there supposed to be a plate under the shift boot cause mine didn't have one.
The MAF is super easy to clean and worse case there dirt cheap to get a new one and about the fastest fix there is i carry a spare with us when we're wheeling just in case
so what year coils off the zj are good for the pathy's
My 92 XE did that would run normal up until running temp. mind you i did take mine swimming but it was my mass airflow that was shot
mines always been the samsquanch finder lol
sorry not all of us use US gallons everyday and even with that 21 US GALLONS is to much for them
