EvilLex03
Everything posted by EvilLex03
  1. K, I got a questions. my rear hatch on my 94 path seams to be lose. when I drive all I can here is it moving around. its not moving much, but just so that all I can here when driveing is it rattiling. What Im wondering is.. is there a way to adjust it ? Maybe the latch or something that I can make tighter ? Thanks. -Mike
  2. BigMike, Those are 33"s on your path ?
  3. Yea it does say on the sidewall, but thats the MAX PSI, I dont want to run the max, do I ?
  4. Is it what you pay for you get ? Are the other lifts that much cheaper then the CALMINI ?
  5. I looked but all I can find is people saying that it cost a lot. I want to know if anybody got it, how it is. and if it comes with everything I will need. Thanks.
  6. How much $ does a shop charge to fix the leak ? Mine sounds like crap !
  7. I got some thornbirds for my path today, they are used. they are 31x11x16, they are prity worn, I was just wondering what I should run for PSI in them ?
  8. How is this lift ? If I just order the lift is that all im going to need ? Thanks.
  9. yea, I knew that it was summitracing.com, I just was not thinking when I posted that ! anyways, I was looking for the part number so thanks.
  10. I can't seam to find the steering stabilizer kit on summit.com, any help ? -Mike
  11. Ok, so you HAVE to bend the 4x4 lever ? am I reading all this correct ? im a bit confused on this... I have a 94 5 speed, is it going to shift ok after a 3 inch body ? what is the best on to get ? would you say that the ac one was good, or is there something that works better ?
  12. Thanks for the help, I just went to the local junk yard and got a new computer for $75 and pluuged it it, all better !!! it was just the computer. -Mike
  13. ok, I will check the distributor cap in the morning. I did not do it yet, but hey maybe thats it ! -Mike
  14. I did not get anything in the motor wet, I was going slow so nothing got into the engin bay. What else could it be ? will a computer work from any year path that style ?
  15. Ok, I just got my Pathfinder, a 94 XE its all stock and I just took it out to go get it a little muddy. Well, I went into a little puddle... well I thought it was little, anyways I got stuck and took on water on the passenger side and I got the computer a little wet. Now it will start up ok but if I hit the gas it dies! I dryed out everything for the most part so do you think that my computer is gone ? what should I do to fix this ? when I was stuck the path was runnin fine till the water got inside thats why I think its just the computer... could it be something else? Thanks for the help. I new at this ! -Mike
