EvilLex03
Everything posted by EvilLex03
  1. Sounds good to me.. I want to get a black one tho.
  2. ANybody got a pic ? Know of a good place to get one ? Im going to get one.
  3. Just wondering if anybody has put an aftermarket Steering wheel on there path ? I was thinking about getting one of those GT Wheels, But im not sure if it would be to small and look funny. Thanks,
  4. I got my 2" body lift in, and it was kinda a pain in the ass, but I got it all in ! anyways, I used the brackets for the front bumper to lift it up 2 inches but it does not seam to be very tight. Im just wondering if anybody did something diffrent with it.. It would be nice to make it stronger so if I do hit something it will work ! I could weld it to the frame, but I did not realy want that in case I need to take it off some time. Any info would be nice. Thanks !
  5. It may be, but it never made this noise when I first got it last year, just seam to have started this summer. I am going to change the fluid anyways, can't hurt. What fluid did you use ?
  6. $2.46 Gal here in western mass, im going to get me a new civic to ride arround in when im not using my path !
  7. I got my 2" body lift today, and im going to put it in on friday. Just wondering if there is anything I sould be watching out for ? and tips to make it go better ? I have never done a body lift before, but it does not look that hard. And info would be nice.. Thanks.
  8. Well, I can't seam to find anything.. im just going to bring it to the local shop and have them figure it out.. Ill let you know what it is when I find out !
  9. I just got under there and tryed to move stuff. Nothing feals lose. How much should the drive shaft turn ? I can turn it a little, or I should say rotate it a litte, but the joints seam to move right along with it. I guess Ill just try the fluid change and hope for the best.
  10. It does shift a bit sloppy. Well, its going to rain all day again today, so Ill have to try to get under there at some point and wiggle some stuff around.
  11. Yea, they seam ok.. They would be lose if they were bad right ? "Im new at this stuff" !!
  12. Its rainin out so I can't go look. I have not looked yet.. it does make a clunking in the chassis, I can just feal it in the floor. its not that bad, I can here it good when I hang my head out the window.. But it does not do it every time. Like, when ever I go to show someone it wont do it !
  13. its a 94 with only 80k on it ! and all the fluids were changed when I got it last year, and that was at like 68k...
  14. That should say "Coasting" not coating !
  15. Ill check that out... I never looked for a broken mount. Like I said.. It only makes the noise when im putting a load on the thing.. I mean when im in gear driving.. If im just coating it does not make the noise.. It does feal like something might be loose under there.
  16. Ok, here goes… When I turn going under maybe 20 mph I can here a noise coming from the back of the truck.. I think it’s the rear-end.. It does it when I back up also, but as soon as I push in the clutch it will stop. I have a LSD rear end so I was thinking that it has to do with that.. Is this normal for it to make noise ? I friend at a local Toyota dealer told me that when it gets hot out that it might start to “chatter” and told me to change the fluid and also to get an LSD additive. So I got some new fluid and the additive, I have not changed it yet.. Does this sound right ? I just want to make sure before I go changing stuff.. Also, I got Castrol 80W90.. Thats the right stuff, right ? Thanks.
  17. derogate, Where did you get that one ? That is the style that I like !!!!
  18. Ive been looking around on the net for a bit now and I can't seam to find a nice looking Brush Guard... I like the ARB one but I dont want to spent that much money. I just want something that I can mount a few lights and that will look nice. I found a WAAG guard.. anybody have one ? WAAG Center Guard Does anybody like this one ? Also, I have a 2" body lift, is a brush guard going to sit lower because of this ?
  19. Anywhere I can here a sound clip of a path with a header ?
  20. Yea, I think its comming from the manifolds. I will just have to get it checked out. prob be better to have a shop deal with it.
  21. My path is ticking bad ! Im thinking about gettin headers for it, my question is how hard is this to install ? And what the heck is that ticking from ?
  22. I already killed my ECU once ! I had just got my path and I did not know that it was mounted under the seat. well, I found out quick ! Is that all you have to worrie about ? Just the ECU ?
  23. I was just wondering if anybody had and sound clips of exhaust on a Pathfinder. I was thinking about just getting a flowmaster muffler. but I would like to know what its going to sound like. I want something that will sound like a v8, not a little honda. How is the gibson cat back system ? IS there something else that will make it sound good ? -Mike
  24. What part of the latch do I adjust ? I looked at it, but im not sure what to mess with. Thanks, Mike
