azscott
1987 w/sport package. Still all stock
Screwdriver Mechanic
Choose
1987
azscott's Achievements
Funny this thread came up as I was curious too. I am going to look at a 1990 2 door that is available locally, rebuilt motor and tranny. Looks pretty sharp. scott
That sounds good. I took it over to my mechaic yesterday to have him weld back the tailpipe that got yanked out and we looked at the rest of the exhaust and it needs to come out anyway. There is a small header leak on the right side...can't see it but can hear it and we all know that it is 99% chance it is broken bolts. For now I will drive it as is and sae up money for headers and cat exhaust. It is slightly anooying to hear the leak but nothing terrible...just hate the tapping more than anything else. Between this one and my 87 Pathy Sport that needs a new tranny and clutch...I should be broke for a while:-) The one nice thing is that 87 is in sweet shape overall...previous owner was anal over it's care.....garaged it for 21 years straight! plus being in Az we don't have rust...yeah! scott
Yah...since it is out I will replace the clutch anyway...not going to cost that much more. Just odd that it only does it in 4th gear. I have tried to get it to do it in the first three gears but it won't. It does it in 4th if you are upshifting and accelerating as from a stop. If you are in 4th alreayd and just stomp on it it won't slip. I tried a bunch of things and if I upshift and let off the clutch and wait a few secs before accelerating it usually won't do it...but it will if you shift normally and accelerate just as you let of the clutch......the RPMS climb...the SPeedo doesn't and when you let of the gas you feel the pathy sorta jump or bump as the rpms drop a bit and the clutch catches and stops slipping. But oh well...new clutch and used tranny going in anyway.....maybe when we take it off we will see. I thought maybe there is some kind of minor oil leak that only falls back on the clutch plate while accelerating from a stop where you get to 4th gear quickly. Who knows....we will see. Thanks guys Scott
Is hooHa the only centerlink available..
azscott replied to azscott's topic in 90-95 WD21 Pathfinders
That's right....I followed that thread for a long while about L&P. I have just read SO many posts I lost track of who it was that had such a bad rep. Well Hooha it is then. scott -
Not that i mind buying one....but I need to replace mine. I had my mechanic look at my suspensions while they were welding part of my exhaust back on. He said the ceterlink was bad...the rest was fine. So i said well let me see what is a better choice than the stock one as I know it is weak. Am I correct that L&P is not around...? scott
Cool....I was not going the Centerforce route...too much money...and I figured an OEM would be just fine anyway. scott
I edited this thread to ask a different question....as I am not familiar with Pathfinder clutches and it has been...ohh...25 years since I replaced a clutch ( 1963 Ford Falcon Ranchero). I am having my transmission replaced with a good used one as mine has 210K on it and the synchro in 3rd is gone. Anyway, I am not sure if there is also a clutch problem and I know the clutch was replaced about 80K or so ago. First off the clutch does not fully engage until the pedal is almost all the way out......but would this be an adjustment issue? Also and more like a cltch issue is that it seems to slip in 4th gear only . Kind of odd in that it does not seem to do it in 1st or second but in 4th gear when i accelerate hard after shifting. I would have thought it would be worse in 1st or second but does not seem to do it then. Since the tranny will be out I will have it looked at but just seems odd and I am not sure if the pedal having to be almost fully released to get full engagement is a clutch or simple adjustment of something in the clutch.hydraulic setup. Last what is a good replacement clutch ( from original post) scott
First off i have read quite a few threads on the header bolt problems and for the most part I am all set. My headers are making the typical tapping sound and I can hear a slight leak so i am getting ready to replace the headers and while I am at it and since the system is old I might as well replace the rest of the system. My question is this. Which headers have you guys found to be the the easiest to install as far as not having to do any modifications. I looked at quite a few and they always say modifications may be needed. I would like to put a catback exhaust on if I can while I am at it. However the goal is to try and keep it as simple as possible and try to achieve as close to straight bolt on procedure as possible and avoid uneeded welding and such. If anyone has advice as to which makers headers and exhaust was fairlt straightforward i would appreciate it. I do not have to try and gain performance but it would be nice also...mainly though I want to shut up the annoying leak and tapping. Maybe the few exhaust options out there are all fairly straightforward and that would be great I just have no idea and I have run into a real Pain in the @ss exhaust job once on an old Camaro and regretted ever starting the job myself:-( Scott
...Huh.....cutting boards...pretty sharp idea....I assume you refer to the thick plastic type obviously. Will have to look at that......did I see you mention that in another thread...seems like it sounds familiar now? Scott
Yah I may go that route...I really do not want to start introducing excessive wear and failure when i drive it daily for work also. So JGC springs in the rear and crank the front T-bars up a bit but not enough to require new arms. scott
Speaking of under armor and sliders...is there a link for skid plates for the Pathfinder.....I have looked quite a bit and have had a hard time finding either sliders or under armor for the older Paths. I saw Calmini had some plates but was not sure if those were only for use with their crossmember replacements or not. I know many make their own. scott
Good information....I appreciate all of this. I do not plan on putting my Path to extremes....we abuse ATV's for that...however we are not just 4x4ing on simple dirt roads.....usually the toughest is having to divert through dry creek beds and runnig up them for a few miles usually only presents moderate size rockage:-) Maybe a mild T-bar crank....a BL and some JGC springs would be enough? Again I appreciate any input. Scott
Well is it smarter to just do a body lift. It would seem this would not do much for clearance unless you put bigger tires..which i am not intending on.....would look cool....but looks don't get me over rocks. It is a sort of dilema....gain clearance and some articulation...loose longevity on some drive train parts. I suppose BL would help to keep the front tires from bottoming on the fenders which is half my issue...and I do not want to just crank up the T-bars as a sole fix. is there an advantage to just doing a BL...besides looking cool...? scott
Here is the link for the Hoohaa centerlink. http://grassroots4x4.com/index.php?option=...ct&Itemid=3
Took a few searches on google was tough to find his website...but it is linked below. Much cheaper than a Calmini solution...about a 1/3. http://grassroots4x4.com/index.php?option=...ct&Itemid=3
