fritz007
fritz007 last won the day on September 21 2011
fritz007 had the most liked content!
About fritz007
- Birthday 11/24/1986
Stock and ready to Rock!
2001.5
Contact Methods
Website URL
http://
ICQ
Gender
Lacey, WA
fritz007's Achievements
NPORA Regular (2/5)
you should also update the pics in the signature on your posts the new rims look way better
2003 Pathfinder Factory Harness
fritz007 replied to ChrisWnorman82's topic in 96-2004 R50 Pathfinders
i just did a quick google search for a Nissan Pathfinder Stereo Wiring Harness and came up with some good picks of the factory set up. Those might help, and they are cheep on ebay. That would be a better set up than just pluggin the pins into the slots because any major bumps and it could cause a short or they could just wiggle loose! Hope that info helps -
good idea i will check that out too, i have just had the thing parked in my driveway half torn apart and all grumpy that i have a moldy carpet
Thanks for all the great ideas, it sounds like i will have to rip some other stuff out to find the leak
Recently i vacuumed out the pathy and noticed that under my driver side floor mat(which is rubber) the carpet was soaking wet, and was curious if anybody knows of common leaks in the front driver side area? Any ideas would help water leaks are a pain the A$$!
what is the deal with the back seats reclining in the qx4? i wish mine did that!! the back seats are terrible, does anyone know what years/models these were on and if they would bolt into any other models?
ahh isnt that typical just nag nag nag
wow u got quite the welcome, way to make an entrance
for sure a switch issue, the wifes headlights were doin something similar and it was the switch. should be cheap to replace or u could pull it and take it apart and look for corrosion that would cause it to short out and actuate the wiper motor... moisture issue maybe with all the snow that u have gotten lately
Steering Wheel Controls/ Airbag Light/ Horn
fritz007 replied to 01silvapathy's topic in 96-2004 R50 Pathfinders
by chance when looking for a clock spring did u notice if it was the same one for a Qx4? -
Any aftermarket header options for the 3.5L?
fritz007 replied to WOT's topic in 96-2004 R50 Pathfinders
keep us posted on any info that you find i am interested in starting some projects on mine and performance is number one -
if u dont mind how much and where did u get it i think that is the cause of my temp/gas gauge not workin?
wow what a time waster, but entertaining
huh snapped off the bump stop... that is extreme you gotta quite being a taxi for fat chicks!
This is what happens when im bored with a socket set
put your socket set down and pick up a welder and get crackin on a tube bumper
