I have found that there is so many shock/spring combo's out there that it really ends up being whatever your happy with, sach's, ome, gabriel, monroe, pedders etc all have good points and bad points,
We went out and found someone that would make new springs and full length custom struts(5 inchs longer than standard) to suit our own design.
That took a long time, more than 6 mths ringing and chatting to people in the industry to find someone that would listen to us and work with us.
The new struts add 4 1/2 inchs of compression and more than 5 inchs more extension over standard, we went the same way with the rear springs and shocks, they are full length custom stuff, just think guys, 5 inchs higher a but will still compress to same depth as the original and more than 7 inchs more extension than originals.
There are some that love ome stuff and some don't, me personally, i have found that all the aftermarket equipment on the market for R50 pathy's has left me wanting more, bars(front and rear), snorkels...what a joke, sump guards, and more.
I have spent the last 12mths designing tube bars(winch and non winch) front and rear, high mount towbar(more than 7 inchs more height than original) and now the full high lift suspenion, the only aust legal 5 inch lift.
Next in the making is a full replacement front suspension set-up, it is a bolt in frame, spring and shock mounts, solid diff, new brakes, driveshaft, brake lines, wiring for ABS,new shocks and springs bolts, nuts, etc
Yes bolt in, no welding
It will give R50 pathy's a totally new outlook, more articulation than ever possible with the factory IFS, more variation in lifts and better load carrying ability.
The 5.7lt gen3 engine swap will also be available as a kit too.
