mennonitemike
Everything posted by mennonitemike
  1. has a no fuel problem. pump maybe?
  2. Nice! maybe I'll be able to hit 600,000kms afterall. Once the pathy is highway worthy again
  3. Thanks! I have a 87 2dr with a Z24i. I think it has 2 injectors in the intake manifold right before the forks that go from 2 tubes to 4 at the head. Maybe I just need to replace the O2 sensor then, I tried scrapping some of the carbon build up off when I had my motor apart. Maybe I did more damage than good...junk.
  4. I put my timing shaft in one tooth BTDC for the distributor/oil pump and then being too lazy to take it all apart again. Naturally I took a die-grinder to the dist. housing adjustment slots to get the amount of adjustment needed to compensate for my mistake. But now I'm concerned that somehow I've affected the fuel system of something because my pathy is chugging a bit at low RPM and loosing power on the highway. Any ideas?
  5. thanks for all the feedback! I didn't even know about the Heli-coils. I was originally going to use those solid piece inserts with the lock pins you have to hammer in. Now to head down to NAPA, PartSource or Autovalue and try to find them. p.s. just to clarify, I'm not heli-coiling my headbolt, just the rockershaft bracket bolts on the six holes closest to the rear of the motor.
  6. So I blew a head gasket a month ago and two weeks after I got it all back together I break my rocker arm assembly. It seems my chain tensioner slipped a couple notches and created some seriour tension on my rocker shaft brackets via the cam and pulled the bolts right out of the head on the last three brackets. Turned my truck into a two cylinder as it's a Z24. I don't wanna take the head off again so I was wondering if I could get around that by either drill and tapping the holes and using thread inserts or just using different bolts and foregoing the inserts altogether. Any input?
  7. that's sweet, got me wanting to get off my butt this weekend and finally put my JGC springs in my 2dr
  8. My pathy has approx 366,000 miles (586,000kms) I just blew a head gasket and have only owned it for about 10 months. besides the head gasket i've only had to change the thremostat and the front driveshaft....oh ya I had to replace the passenger side front corner cause it was smushed before it was brought to the auto wrecker I bought it from. besides the rad everything else was cosmetic.
  9. wow this is an old topic...well I have an 87 pathy with a carburated Z24 that has 584,000kms on it. Still good for a snow pile climb or mud bogging!
  10. Mine is silver with primer, one red fender, the other fender and door are charcoal grey, and the hood is white. But it used to be all silver.
  11. That twin spark idea sounds cool, I'll have to look into that. It doesn't seem like there are many fans of the old Z24, it's too bad, mine has 584,000km's on it now and it's still going pretty good.
  12. Well the motor that i have (which is the motor in question) is a twin spark carburated Z24, i guess but from what I've heard the second set of plugs is just an emissions thing
  13. So I was wondering if anyone knows if the intake/exhaust manifolds from the TD27T turbo diesel would fit a Z24? just contemplating my power adding options without a vg30 swap.
  14. I got mine for $530 from a wrecker. It was in an accident but they included anyparts I needed to get it on the road in the deal. The clock is showing 583,00km's might be a contributing factor but it's still strong enough for brake stands with my 31's
  15. I bought my Pathy from a wrecker with 580,000km's. Fixed the munch passenger side corner. And now I want to change the oil for the t-case, tranny and diffs. I don't have a manual, what kind and vicosity of oil goes in the t-case, tranny and diffs? Clearly a rookie ~Mike
