BCangler99
BCangler99 last won the day on September 23 2025
BCangler99 had the most liked content!
2 Followers
    99 SE, manual, - 2" AC coils with 4" SFD, kyb struts, missing link, LR RKB101060.C8, Bilstein 5125 33-185569, Warn Hubs, -3.75 backspacing, 33x12.5R15 Duratrac Wrangler, full size spare
    British Columbia
    Canada
BCangler99's Achievements
NPORA Veteran (3/5)
12
  1. There are r50 sfd groups on Facebook and some write ups floating around the internet. Cal Rodriguez did a YouTube video installing his sfd that will give you a good idea. The SFD kit is subframe drop blocks strut spacers Engine mount blocks Longer panhard drop bracket Missing link lower control arm cross brace Mounting hardware Steering extension extended brake lines
  2. Not able to upload photos with insert image 2" AC coils with 4" SFD, kyb struts, missing link, LR RKB101060.C8 about 6 inch rear lift, Bilstein 5125 33-185569, Warn Hubs, -3.75 backspacing, 33x12.5R15 Duratrac Wrangler, tire carrier with full size spare https://imgur.com/gallery/AIvp4br
  3. The front AC coilsprings are closer to 2", but get whatevers in your budget. You'll want to check your struts out before buying new ones. If they're old you can just get new ones. You can get your camber bolts from most local shops, they aren't uncommon. When you go in for an alligment they can do the camber bolts if you can't do it. There's a new tariff today though canada post shipping to the states.
  4. If you want the parts and you will pay for the shipping I will gift them to you. On one condition you post before and after pictures. You will just need to buy yourself front coilsprings or spacers granting your struts are still good. The whole install should be quick
  5. If you want the parts and you will pay for the shipping I will gift them to you. On one condition you post before and after pictures. You will just need to buy yourself front coilsprings or spacers granting your struts are still good. The whole install should be quick
  6. 208tyler member here and on YouTube fully explains in different videos lift This one is for rear
  7. I'm selling Bilstein Shocks 5125 33-185552, AC rear coilsprings (the 2inch lift ones assuming they are LR coils) Used them for less than a year. Got different set up after doing sfd. They are in good shape, I can ship to you. I'm only asking 100$ canadian for the shocks and coilsprings. You will just need to buy front spacers or front coilsprings, that is all you need for 2 inch lift, won't need extended brake lines.
  8. Most shops will estimate around 2000$ canadian for a clutch kit parts $ labor
  9. I can confirm the "AC springs" cause very harsh top out. I've had the AC springs with 1" spacers up front for about 7 months with no problems besides the top out. The warn hubs will save your cvs
  10. Sounds like a good truck and it's a 5 speed. Do you know if he's done the timing chain and water pump? How is the rust? 6500$ US asking price is a bit much. But sounds like it would be a solid rig to last you many years if he's kept up on it.
  11. I'm pretty sure OME discontinued R50 lift components. So if you can find a set would be great. The 9447 will give 2-2.5" of lift in the rear. Your best bet may be AC 2" coils in the front but the shipping costs quite a bit. Dobinson coils for front are a good option also.
  12. Thanks. I love the AT3s so far, they're pretty quiet and surprisingly lightweight. I'm happy I went with a 31" A/T tyre instead of getting a 32 or 33" mud tyre. The 31" at3s feel just right and I didn't do any trimming to make them fit. They're bit pricey but definitely quality. When I get a SFD will upgrade to 35" falken wildpeaks.
  13. 208tyler on YouTube has full explanation videos discussing lifts and wheels for the r50
  14. Been following the forum and contemplating for a few years to get a lift and finally did. 99 SE, 5 speed manual - front suspension is AC 2" coils with 1" spacers on kyb struts, rear is NRC9447 with Sumosprings (SSR-625-40), bilstein shocks, SF Creations Control Arm Crosslink, Warn Premium Manual Locking Hubs, Pro comp -3.75 backspace with 31x10.5R15 Toyo Open Country AT/III tyres I'm unable to upload pictures so here's a link on imgur. https://imgur.com/a/SaBX7iJ More updates to come. Thanks Devin
