Jimmie
    1995 SE Cobalt Green
    Tennessee
3,759 profile views
Jimmie's Achievements
  1. Anybody have any for sale? Jim
  2. Amazon.com: Kison Ignition Switch, Manual Operation, Black : Automotive I have repaired a few of these and is an easy fix. The first starter issue that I had years ago I replaced the starter and new relays and all it was this switch in the steering collum attached to the key switch. The small contacts wear after a lot of use. Jim
  3. I went through all of that on my 95. It turned out to be an $20 dollar ignition switch that was easy to replace. Amazon.com: Well Auto Switch-Ignition Starter Compatible 1987-1995 Pathfinde; 1996 1997 Pickup 1986-1994 Hardbody Pickup (D21); 89-94 Nissan 240SX 48750-01G00 487501G00 US-150 US150 : Automotive
  4. Rattle Can paint last for about 1 year. The paint above is 2 stage urethane and will last for years.
  5. Argent Wheel Silver Sheen (Satin) - Hot Rod Flatz Argent Wheel Silver Sheen (Satin) Medium, Urethane Flat Paint, Qt Kit — TCP Global
  6. The sheet metal. I looked at a 2wd truck this afternoon and you are right about not being flared as much. The trucks around here are easy to find in the Pull Your own Parts and the Pathfinders are getting hard to find. Jim
  7. Are Pathfinder and Pickup fenders and inner fenders the same ?
  8. Thanks, I had everything covered up using my torch and welder getting the broken exhaust studs out. I went back and uncovered the flange and the was just a metal donut ring in it and I pried it out with my pocket screwdriver. Both gasket and ring were in the box, and I did not know which one to put back. JIm
  9. In the manifold kit I ordered the flange gasket has a metal O-Ring. Does it go on top of the gasket or below ? Never used one like this . Jim
  10. Can you use MT-90 on a Pos trac rearend? Do you add any additive to it after the change ?
  11. Will the studs need to come out of the manifold first? Or can I just remove the nuts and leave the studs in. It looks like there is not enough room to double nut them. Jim
  12. I ordered the 140-V5004 and they are 8 x 1.25 not the 10 x 1.50 studs. what is the correct number. ? Jim
