chrisfromthelc
chrisfromthelc last won the day on July 9 2019
chrisfromthelc had the most liked content!
1997 4WD Pathfinder
36-40
1997
Arizona
Country
chrisfromthelc's Achievements
NPORA Regular (2/5)
26
I guess I'm one of you now.
chrisfromthelc replied to chrisfromthelc's topic in 96-2004 R50 Pathfinders
And just like that, I'm rolling on into the sunset with the Pathfinder. My young BIL moved to AZ to get out of a bad housing situation and start over here, and was in need of a vehicle. Since the Pathfinder is still solid (I drive it about half the time and my F150 about half the time), I decided to put the halt on building it out and sell it to him for "cost" (basically just what I paid plus the cost of some maintenance/repairs I made on it). We'll do the timing belt in a couple of weeks, but I think my next rig will likely be a Jeep WJ. I got a bit trigger happy on the Pathfinder since it was such a steal, but after having it a while, I've decided that a WJ fits more of what I want to do with my rig. I'll be popping in on occasion, since the BIL will want to make his own upgrades, and I'll likely be the one helping him with those. -
12 volts already is at the bulb, so any wiring you add would need to be the ground, not 12V. The switches at the light itself switch the ground. Very important to get that part right. I'd have to pull one of the actual lights themselves, but it might be possible to tie into the switch with your new switch wire without needing to diode-separate them. If you tie into the wiring outboard of the switch, you'll most likely need the diode to isolate the ground signal.
Yeah, I'm also interested in this. I don't have controls on my steering wheel, so that would be a pretty nice upgrade.
Yeah, actually, that's a good point. It looks like the alarm system is tapping right after the door switches (didn't think about that initially), so that should trigger the "open door" dash light. This may require more extra wire running than would make it worth it. Looking at the schematics again, I think you'd have to catch each light, instead of just one easy location like I thought at first. It looks like there's no central ground to hit except for the door switches themselves.
So, the door switches are grounding switches. You can apply ground to the switch, and it should power the lights up. Any of the door switches would work. If you want to double check wire colors, it's page EL-81 in the 1997 FSM, but you can just pull the switch and look at the wire color there as well. I'd probably just pick up the front driver door switch wire with a t-tap, and ground on the opposite side of the switch with a 2 conductor wire. Run that back up to the dash where you want to put the switch. When you hook it up to your switch, you're basically bypassing the driver door switch. That's the simple implementation of it. I would maybe also think about using a rely powered off the 12v ignition feed to provide a failsafe. Make it so that the ground side of your light switch is disconnected when the vehicle is off. That way, you can't accidentally flip the switch on and leave it on all day/night, running the battery down. When the vehicle's off, the switch is dead.
So, if one were to replace the radiator for whatever reason, it would make sense to bypass transmission lines then, or even go with a separate cooler at that point? I don't have any leaks on mine currently, but there are some suspect looking spots on the fins from a previous accident. I was thinking about replacing it at some point before it became a problem.
zakzackzachary's 2000 R50 new to PNW from AK
chrisfromthelc replied to zakzackzachary's topic in 96-2004 R50 Pathfinders
@RainGoat I had been thinking about something like this, but for holding a solar panel that could slide out over the windshield/hood when parked while camping. I didn't realize there was a product out there already, but this definitely gives me more ideas... -
Yeah, I would definitely go down the balance path. I had a 55-65MPH wobble that I could not fix. No bad bushings left to change, but it couldn't have been balance because it was just done. I took it to the tire shop and got it road force balanced, and the wobble is pretty much eradicated. One of the tires wasn't set on the wheel properly and it had too much weight trying to balance _that_ issue out.
When I got my Pathfinder a bit over a month ago, the previous owner had bathed it in some sort of deoderizer/scent, obviously to cover up smoking smells in it. While the vehicle was pretty clean, a close look (under the driver's seat, for example) revealed cigarette ash. Now, a smoker's vehicle isn't an automatic disqualification for me. I don't smoke (and definitely not in vehicles), and I've always had good luck getting the smell out with a very thorough cleaning and usually a fabric shampoo (seats and carpet). This one, however, was the worst by far. The smell wasn't actually even the smoke that was bothersome; it was the scent used to cover up the smoke smell. I have used every trick in the book on this. Super deep cleaning; even cleaning A/C ducting, pulling dash, interior , and door panels, shampooing the carpet and seats, all manners of neutral deodorizers, baking soda, vinegar,...when I say everything, I mean everything. No matter what I did, it still smelled like this stupid Axe-body-spray-like air freshener once it heated up again from the sun. My wife wouldn't even ride in it because it aggravated her allergies so much. I finally broke down and bought an ozone generator from Amazon a couple of days ago. It was cheap enough if it actually worked, and with Prime, it would get delivered next-day. I got it in, set it up on the vehicle, and ran it for the recommended 30 minutes. Then, I left the vehicle open with a fan to ventilate it for about an hour. I went to pick up some things from the store, came back, and once the hour for venting was up, I went to smell the truck interior. It smelled like....nothing. It had no scent whatsoever, even in the rear seat backs where it was undoubtedly the most potent previously (I guess that's where they set off the scent bomb at). I closed it up and let it sit out in the hot sun all afternoon (which is guaranteed to heat up whatever smell you have and bring it to the forefront). After 6-7 hours of baking in the Arizona sun, I opened the door again expecting the scent to be back at leas faintly, and still...nothing. I was skeptical that ozone would really be that effective, but I'm now a believer. If you've been battling smells in the interior, the small cost to eliminate them are worth it.
Automatic AC - Blower Intermittent
chrisfromthelc replied to Inyourface1650's topic in 96-2004 R50 Pathfinders
Not all do. My 97 Pathfinder doesn't. -
What can be read from the OBD-II?
chrisfromthelc replied to Strato_54's topic in 96-2004 R50 Pathfinders
Ah, that sucks. Maybe I'll look into a different solution..that's pretty far down the list for now, though. I'd like to have something that I could tie in data from add-on sensors (like trans temps). -
I think long term I'll go with Scan-Guage..the BT dongle works for what I need for right now (quick code checking/resetting/etc). Do you happen to know if it can read external add-on sensors? -
I think we'd be fooling ourselves to think that any one location is "central enough" for everyone to have a chance at making it. Even the most central location would be really too far for anyone to want to drive, I'd think. I know that even in a perfectly running vehicle, some place like ID or OR would just be too far (20 hours to Portland, OR, as a quick search reveals). It might make more sense to break it up regionally. That would give more people a chance to gather in central locations to smaller areas, rather than it just being luck of the vote as to where something happens. There's a whole eastern half of the country that is not represented by the poll; supposedly Pathfinders were sold there, too. Having been involved in planning wide-scale things like this in the past, it really does just work better to have smaller, regional events than expect everyone to agree on a singular location that's not accessible for 95% (or more) of the hopeful participants.
I have a 1997, and that list looks pretty close, if not spot on. I bought this adapter from Amazon, and it works fine. I use it with Torque. I have not gotten Nissan Data Scan II to work with it, though, but that might be due to it being such a cheap one...I need to pick up one of their recommended ones and try it. -
If it were here in AZ or even SoCal, I would probably try to make it, but needing to travel more than 5-6 hours or so would probably keep me from being able to do. (that's assuming I get this heap up and running the way it should in time)
