MTGunner
Everything posted by MTGunner
  1. Mine is the manual, stick through the floor. Automatic transmission on my 2000 SE model. Guess I am being too specific when I ask either ATF or 75-90 GL-4. MTG
  2. Have read the maintenance manual for 2000 Pathfinder 4x4 for changing transfer case fluid. One says OK to use correct ATF and another states 75-90 gear oil. Which does anyone suggest? This Pathfinder will be for back roads and mild off roading. Going about mild build for daily driver and hunting fig. MTG
  3. Minimum distance from inner edge of tire to strut is approx. 1/4” to 3/8” static. I will monitor wear for indication of misalignment and or rubbing. Thanx! MTG
  4. Will check gap for width. Seems minimum. MTG
  5. Hello all once again. Now, I put 265/70R16 Falken AT3W tires on my 2000 Pathfinder. The clearance in the rear is good, no rubbing. The clearance in the front has me concerned. There is little between the bottom of the strut, the base where the spring seats, and the inner edge of the tire. Have not had rubbing that I know of but so little clearance does concern me. What think you all? MTG
  6. Seems like a simple 2" lift to install. Have to give it some thought. Thanks. MTG I looked at the website and the reviews. Do not have a spring compressor. Can this be done without spring compressor? MTG
  7. No real reason. Just think it unnecessary with good tires and judicious off road activity. Here in the SW desert there is lots of trails, but no real rock climbing that I am in to. Yes, I do want to avoid cactus, mesquite thorns, some rocky terrain and etc. But, I do this as need be when I am out offroading. Just want best suitable safe options for my off road needs. Do not need to build a romping stomping off road machine. That I have in my Xterra at home in Montana. If, in fact, I do decide to do a 2" suspension lift, which kit would I best choose? MTG
  8. Thanks mojo, the heavier load range and thicker sidewall would be better here for my off roading. Our home is in NW Montana although we spend our winters in SW New New Mexico. Our 2000 Pathfinder stays down here at our lease lot and no snow to speak of. But, lots of off roading in the desert and mountains. I would like to avoid a 2” lift but would do so if need be. Fuel mileage is not a issue as we put about 5000-6000 miles on each winter here near Deming, NM. I like the idea of the LT tire for better rock resistance. I know that no tire is indestructible regarding rocks and rough roads. But will continue to listen to what all have information to offer before I make a decision. MTG
  9. Pathydude17, Walmart lists two Falken AT3W tires on the same page. One listed at $98 and the other at $120.....? Both look identical but different order numbers. Micah, who makes the duratracs that you speak of? MTG
  10. I will consider the Falken as they are listed as a LT, light truck, tire. I have an older set of Nexen RA8’s on my 2000 Xterra that still service well. I have been considering a 265/70R16 for my 2000 Pathfinder with a 2” lift. There are currently 255/65R16 General tires on it now, but looking for better tread, better sidewall and overall better off road performance. I looked at the Falken Wildpeak AT3W’s on Walmart in the 255/70R16XL. Seem to be a good match. Actually want to look at the sidewall construction as do some off roading in rocky terrain and with this model may not have to do a 2” lift. Thanks for the heads up. MTG
  11. OK, have been searching tires for my 2000 SE. I have decided upon 265/70R16 with a 2” lift. Now, I have looked at many tires online and in Walmart. Has anyone experience with Nexen Roadian Pro RA8 tires? This will be for moderate off roading and daily driving. The RA8 has a 5 star rating with multiple tire online sellers. Just looking for someone with practicle experience. MTG
  12. Have been following your thread. What is the make and model of the roof rack? I like the idea of the traction board and mount. I would manufacture the mount for the shovel, traction board and spare fuel can. BTW, my spare fuel can for my 2000 Xterra is a 6 gallon marine fuel can that fits great. I will mod up same for my 2000 SE. This Pathfinder spends its’ time in SW New Mexico where we have a place. Will not go to Montana. Lots of off reading here in NM. MTG
  13. We spend our winters in SW New Mexico to hunt the quail, enjoy not having to shovel snow and there is a tremendous amount of off roading opportunities here. I have done extensive winter off reading in many northern states. Cannot say that I miss the cold and snow. We will be home to NW Montana mid April to prepare for bear and turkey season. Have lots of work, chores, maintainence to do on our toyhauler, my Xterra, home projects and more. Guess you might say we will be returning to mud season. Good ‘nuff! Always enjoy getting home. Keep up the good posts. MTG
  14. Has anyone taken the adjustment assembly apart to reengineer/replace the plastic adjusting screw with metal parts? Both sides of mine are stripped as the low beams are truly LOW beam lights. May have to mount 4” LED cubes for better lighting. MTG
  15. Micah, have been following this thread and missing a Montana right up until you posted the pics of your Pathfinder in the snow. Yes, I miss home and will be back in NW MT mid April. I found a very nice 2000 Path SE here in SW NM that I have been upgrading. Albeit, it will not be coming back to MT this spring. I have a 2000 Xterra at home NE of Ronan that I wheel all over Montana. Another great Nissan that I have done extensive upgrades to and will continue. My hunting rig. We spend our winters in SW NM and I do lots of off-roading in the desert with my Pathfinder and ATV. Warmer here and no snow to deal with. Quail season runs through mid Feb. and lots of desert to roam. Keep up the thread and lots of pictures. MTG
  16. My owners manual suggests changing engine oil around 3750 miles under normal conditions. I am running 5w/30w high mileage synthetic. What is everyone changing their oil and filter at? MTG
  17. Dumped the diff fluid yesterday and drained for an hour. The drain plug magnet had but a small amount of black debris, looked like black mud, no metal chunks. Refilled with Lucas 75-90 synthetic diff lubricant. The droning noise has dimished to a point of nonexistence at this point. At this point I will monitor for other noises. Tough being a person that hates noises, rattles, squeaks and the plethora of annoying little things that come with a used car. Sure do like my R50! MTG
  18. OK all, this far I have replacedfront wheel bearings. Cleaned up a bad brake job as the pads were no being allowed to float on the right front wheel, very tight and not installed correctly. Checked the universal joints to find no fault. I had a good friend ride in the back seat while I was driving on a fairly smooth road an$his opinion is that the rear diff gears are a small bit loose. He said, and I quote, “it will probably only last another 100,000 miles in this condition. Well, I will drain the rear pumpkin and look for debris. If nothing significant I will refill with synthetic diff lubricant and move on. Front end steers great, brakes work great, rear end noise is minimal. NEXT!
  19. There is a droning/whining noise somewhere in the drivetrain of my 2000 R50 4x4. I checked the rear diff for fluid and all is well. The rear tires show no different wear from other tires. I will check “U” joints tomorrow. Will also check rear axle bearings by jacking rear end and placing on jack stands. Droning/whining noise diminishes with higher speed. But, am concerned. What think you all? Thanks for the input. MTG
  20. These will be approx. 31” in diameter. Will there be rubbing issues without a lift in your opinions? There are 255/65R16 on that are 29” that do not rub. MTG
  21. OK, following this thread and can someone clarify the advantage in this modification. Has been said that it improves handling and makes suspension stiffer. This would be a easily fabricated link if the advantages are truly significant. Please elaborate more. Thanks. MTG
  22. Checked the strut nut for movement to find none. Will have to wait for warmer weather to jack up, put on jack stands and inspect link ends and sway arm bushings. Those I changed on my 2000 Xterra front and rear. Guessing that this may be the culprit. Will keep this forum informed. MTG
