zenopathy
Everything posted by zenopathy
  1. A little late to the party... I've got a 2002 and the 33 1855569's with the NRC 9449's and mine have the tendency to fall out at full flex, just like @micahfelker. As for the strut bushings, I had that clunk for the longest time and finally got sick of it. My uppers had wore out incredibly fast, leading me to believe they didn't fit in the first place. Ended up getting polys for bottom and top (Energy Sus. 9.1808G) and lathing metal sleeves of different IDs for the upper bolt and lower stud, that fit in the bushings and around the bolt/stud.
  2. I picked up an aluminum valve cover from a 2001 LE at the local JY, after finding multiple spark plugs soaked ? . Swapped into my 2002 SE after wire brushing and a new gasket. Runs and fits perfectly and ties in nicely with the manifold! Not sure about changing the cylinder 1 coil pack, it was pretty much plug and play.
  3. I had similar issues with my 2002 SE. It ended up being the POS; rear crankshaft position sensor (the coincidence of this acronym was astounding considering the problems it gave me). I'm not sure if the symptoms would be identical had it been the front (CKP) crankshaft position sensor, but I was experiencing some of the same issues (i.e. shaking and misfiring while starting, something almost sounded clogged; rough idling, fuel covered spark plugs, strong gas smell.) However, I did begin to have starting issues and at one point I was stuck at the top of a mountain with a fully loaded rig because of it. As for the DTC, I'm not sure if it actually threw out a code as my SES light was on before the problem started, and still is on. (I have not yet reset it). After replacing air/fuel filters, spark plugs, an MAF sensor, etc. I was getting frustrated, so I feel where you're coming from on that front. I wish you the best of luck!
